BELTS
OEM belts? I noticed some aftermarket belts did not match the V angle of the pulleys. Pulley alignment? If the pulleys aren't lined up you'll get increased wear. You should be able to see alignment problems visually, or put a long straight-edge across the pulleys to check more carefully. If the belts are loose you might be getting a lot of slipping, doesn't always make noise. Try spinning the pulleys by hand, see if any are turning hard.
What are the symptoms that cause you to keep replacing belts?
ok, i have now replaced my belts 3 time in the past 18 months and they are now needing it again. any ideas to what is causing this. none of the bearing are making any noise.
Are you sure the pullies are spinning?
My idler pulley for the alternator belts was siezed up and I couldn't even tell while it was running :eek:
It wasn't until I after I loosed the belts all the way and tried turning it by hand that I found out it was stuck :doh:
It had probably been that way for months :o
