New 10w-30 oil + oil filter.
While driving, I can watch the oil pressure gauge drop as the truck warms up to highway cruiser temp, until the gauge hardly registers at all.
FSM Spec:
With engine at operating temp,
Idle: 4.6 PSI or greater
3000rpm: 36-71 PSI
Not trusting the gauge, I hooked up a mechanical gauge today. Warm, but not hot, the pressure at idle and 3000 rpm test to right in the middle of acceptable ranges.
But, as the engine warms up to hot, the idle drops to 3-4 psi (bouncing needle) and at 3000 rpm pressure drops to ~30 psi.
Obviously, these values are not good. I am not sure what to do to correct the issue.
Should I try 20w-50? (worked for low pressure on my '74)
New oil pump?
Help!?
TIA
Check this thread for background- https://forum.ih8mud.com/80-series-tech/210792-low-no-oil-pressure.html
FSM Spec:
3000rpm: 36-71 PSI
New oil pump?
Help!?
TIA
