Bellhousing to Engine torque specs (real time)
Mikesta
Never decruiserfied
Missouri
Website
www.showmerents.com
I've looked in the Body and the Engine manual for the 2F. I've also searched here on mud for "bell housing torque" and "bell housing specifications", "bell housing specs" Etc.
I see the specifications for the Flywheel in the book.
I've also seen threads here with all the specs. If you have it handy, please pm me or reply. Thanks
I realize your trying to be precise and thats always good, but I've never torqued a bellhousing, partly because it is in some awkward areas. But the torque isn't that critical, it just needs to be tight, i'd say around 80 ft lbs, I always just use a 1/2'' impact though
:hhmm:ok, great, I'm not going crazy... yet... and how the heck did you get your inpact in there!!!
I thought there was a standard bolt torque chart somewhere that specs out grade, diameter, and pitch. Use those numbers when nothing is listed in the manual.
I would think that even an inexpensive 1/2 impact would be way over 80#. John
I've always just tightened them with a 1/2" drive and have never had any problems. Don't worry about it too much :)
Good times guys. I'm all zipped up and ready to join the tranny/engine together. Thanks so much for the help! I was going crazy with search here, after 45 minutes searching the FSM and here... I gave up.
I've been searching and looking for a while. I wanted to torque it all right, but i'm goin w/ the good nuff method on these. Full 2F rebuild, trans and xfer case built, ready to mate and burn rubber.
I think the bellhousing to block bolts are the same bolt as the transmission to bellhousing bolt (M12).
If that's the case then the torque spec is 47 ft-lbs
Thanks! I was going to torque to 47 on it. Last time I mounted it, I used blue loctite with no correct torques. I’ve spent a considerable amount of time cleaning threads...won’t be doing that again. Using never seize and torquing to spec this time.
