Bearings and races
Ingerland
I am half way through my front axle job and am currently replacing the wheel bearings.
In the box there are two parts - the bearings and the bit the bearings fit into (are these called the races?) Anyway, I am guessing that the races have to be changed at the same time as the bearings.
The old races (circular/conical ring) are quite easy to tap out - is there a technique to knocking the new ones in? Is a brass drift recommended? I can't see this being very satisfactory as there is only a small lip to hit against.
Please can someone who has done this explain how?
Many thanks, Jim
Yeah you need the tool to do it right. It is pretty easy to get them going in wrong and ruin them. With the tool it is simple and fast.
I just use a steel punch and a 3lb hammer. I've done a couple of knuckle bearing sets and a couple of wheel bearing sets like this no problem.
Yes, the races will need to be replaced together with the bearings. I started with using the old race. Put it on top of the new one. Drive the race in by tapping the old one with the brass drift. Constantly check the progress, you don't want to drive in too far with the old race as it will get stuck. Once the new race is in place, you can remove the old race, hit the new one with a brass drift. (keep the drift on the lip not on the surface of the race.) It is important to tap the race in evenly. Good luck.
I did this last night ... worked fine! Make sure you tap around the circumference to ensure the new race is going in square. Also make sure the new race is fully seated.
I would recommend a race/seal driver set, or a brass drift. I used the brass punch and it took forever, but it worked. After using the brass drift, I can only think that a steel punch would definitely /scratch the race or the hub.
When I do it I only drive on the upper lip of the race and I haven't scratched any of the races when putting them in. They are wicked hard.
Maybe I'm doing it wrong:meh:
Hijack newb question: is lubricant used when pressing the new races in, or should everything be bone dry??
Dry, is what I have done.
