Battery Tray location when adding AC
Fayetteville, North Carolina
For those who have added AC to their late model 40. Did you have to move the battery tray? Did you use a battery tray designed for stock AC installation? Do you have a dual battery setup? IF so where did you cram all that in the engine bay?
Here's a couple pictures I found on the mud. Forgot who built it.
I saved them on my phone. I am a bit fuzzy on remembering which thread they were from.
Guys, those pics are my truck. The battery support is a stock battery support. We put some heat on it and bent it back - probably about an inch. I already had the AC compressor mounted so it was easy to see when it was moved far enough. We did have to extend one of the battery support legs. I can get under there & take pics of the frame mounting holes if needed, but I think we used one of the original battery tray bolt locations, and used another existing hole in the frame with a captive nut.
Let me know if more pics will help you.
Good Lord! That engine is sharp! Are these images you bookmarked/saved? I have seen this for sale. Supposedly it is for use in a FJ40 with OEM AC
Do you know what model this came on or what the part number might have been?
