Battery tests 0V, then fine
MDarius
I break stuff.
Bountiful, UT
Short story: no start, no power at the dash. Tested the battery with the multimeter and it read 0V. I jump started it and drove to autozone where they tested it and everything checked out. Could not find any loose wires, but my test was terminal to terminal. What's up with that??
Testing a battery is more complicated than just checking with a multimeter. It can test good (12V) and still have bad cells.
Maybe your meter was set to read AC volts instead of DC? :meh:
I suspect that your meter probes were on the clamps as opposed to the actual battery terminals and one of them has a bad connection. It is extremely unlikely that a battery would be completely flat (0 VDC).
It is also not likely that a completely flat battery would load test properly.
I have seen batteries that had bad connections internally to the terminals. Can allow intermittent connection. On two of these batteries the positive post was able to rotate 360* plus.
I thought about that as well. I wonder if the jump start welded the connection. Possible, but unlikely.
the battery developed a "surface" charge after getting jump started. But, the AutoZone equipment should've been able to detect a bad cell or something along those lines.
Do your own load test at home by disconnecting the coil wire and place your multi-meter leads on the batt terms. Have someone crank and see how low the battery voltage drops down to.
Thanks everybody. I just got back to town. I was on my way to Southern Utah for spring break with the fam when I posted the question.
To cover some of the speculations, I wondered about my tester during the initial check. I checked my other vehicle the same way and it tested fine. Went back to this battery and got the same 0v results. My test process (with just the volt meter) was good. I was directly on the terminals, not the clamps, + to +, - to -, DC 20 on the meter, and I double checked the connection of the leads at the time. I do suspect a short in the battery.
After Autozone we drove on and eventually stopped for lunch. I tested the voltage when we stopped and then again when we left. It had dropped nearly a full volt in about 40 minutes with the key off. Some parasitic discharge, probably wouldn't account for 0v though. I picked up a quick disconnect at the parts store and rigged it in place rather than cancel the trip.
Even with the disconnect in place I lost voltage overnight. Probably time for a replacement battery.
This week I'll remove the after market alarm and remote start the PO had installed and see what happens. Maybe this will resolve the parasitic loss. It will undoubtedly solve the problem of having my ignition disabled in the middle of the desert and no way to shut off the alarm or start the truck. (a story for another time) I'll eliminate one thing at a time.
I'll do that and let you know.
By the way, the initial test was 0.2 volts, but I thought it was insignificant to point that out, so I rounded down. Maybe that was misleading...
When switching off you said you lost 1 volt, that would be normal. Battery is 12.6 fully charged after standing for a few hours. Run the engine and the alternator will push it to circa 14v. Switch off and the drop will be to 13+, wait and hour and then your at 12+.
There are a lot of variables here, but before you go any further and if the battery is a couple of years old I would go and buy a new one rather than be stranded. Sort the problem later but at least you won't get stranded.
regards
Dave
