Battery Terminal
Kalifornia
Website
www.pvcruisers.com
Hi Guys-
I am running a second battery with aux fuse block. I have a 4 gauge going to the battery on the positive side and leaving the positive side another 4 gauge wire going to the fuse block (130 amp block).
My questions is (don't laugh):
How does one join (2) 4 gauge wires at a battery terminal in a clean manner?
I've seen the "Bling" options on ebay for audio systems on ebay:rolleyes:
Any other ideas?
Thanks
Seth
Military style clamp. You'll see pictures in some of the dual-battery threads.
So.... I 've spent some time searching and came back with nothing. If you have any links, please let me know. Thanks Seth
https://forum.ih8mud.com/showthread.php?t=36775 post #2 has some good pics. Also, does this help out?
This post shows a pic of my setup with "military style" battery clamps.
https://forum.ih8mud.com/showpost.php?p=1318565&postcount=15
You can get these clamps at stella maris too, but they are called "marine" and/or MilSpec:
https://www.stellmar.com/content/electromech/BatteryTerminals/html/3534_35.php
Also shown in the picture in the first link is a power distribution post that I also got from Stella Maris. This allowed me to move all the auxillary wires off the battery and to a remote location, giving a cleaner set up at the battery.
https://www.stellmar.com/content/electromech/PDP/PowerDistributionPosts.php
I've had good success with the product from Stella Maris. The parts have a low unit cost, but they have a minimum $15 order...
I'm not sure what fuse box you are using, but can you connect the two cables at the fuse box. Terminate each in a ring terminal then bolt the two rings back-to-back to the fuse box.
Thanks guys. This is all very helpful...
Del City Wire is a great company for parts, but their tech is a bit iffy. I was headed down the road y'all have suggested only to be disuaded by the Del City Tech.
Thanks. I now know I was headed down the correct road.:beer:
I was looking for the size of the studs and whatnot on mil-spec terminals, and found that this site has a full description http://www.ecvcinc.com
here is a gif w/ the dimensions. It appears that the stud is 3/8" and that the bolt to tighten the clamp is 5/16" Thought this might be good info for someone else.
Oh, and for the trivia-fans out there, the antimony content of the lead of the body of the terminal must be between 4% and 7.5%. Who knew? :)
I have a pair of SCOSCHE UBT1 battery terminals. Similar to these: http://www.scosche.com/efx.aspx?CategoryID=52&ItemID=PDBTMI
The ones I have will take two 4 gage and two 8 gage wires. I found them at Walmart in the auto audio section and I don't think I paid much more then $10 each.
I have a bunch of High quality 4 gage that I plan to build my own cables out of. I Will also have a set of big plugs at each end to hook jumper cables too or swap winch from end to end.
I am actually going to run each battery to a Power switch that will allow me to choose what battery is primary or gang them for extra power for winching. http://www.westmarine.com/webapp/wcs/stores/servlet/product/10001/-1/10001/91533/10001/297/207/9
I will have a 80 amp isolator so that as soon as the engine starts both batteries will be on charge. All accessories including a 12v fridge will be running off Battery #2 to isolate the start battery to make sure I can't possibly kill it when camping. I am thinking of only hooking the start circuit and starter to that battery so even a open door with the dome light on will not effect the batter that starts the truck.
had an interesting conversation with the auto electrician yesterday regarding my mil-spec terminals. He was adamant that they were crap. Complete crap.
His reasoning: they are lead! Good for fishing! Bad for battery.
I smiled and nodded and told him I'd get right on it. He told me where to go to get "metal" terminals and I smiled and nodded. But after a little while (he really doesn't like lead terminals!) it got me to questioning it a little. After all, we know that tinned copper is the way to go on cable ends. Does that mean lead is bad?
Then I got to thinking some more and figured that the battery posts are mostly lead anyway, so it can't be too bad.
Just thought I'd share
Here is what I have installed
I've not seen that before. What's it called and where do you buy those multi-gang plastic doohickies?
Is there really much of a difference between the lead and the tinned copper terminals?
