Battery Drain
Tulsa, Oklahoma
I have read some of the other threads on here. I have a drain that is eventually killing my battery. I pulled one of the battery cables and put the voltmeter between the post and the cable. I am getting a reading of 0.06. Is this a draw on the battery? Also is this enough to kill the battery in a short period of time? I suck at electronics and the voltmeter isn't even mine it is my neighbors. Thanks.
Hey I've got a 73 and just went thru this problem and a few more. If you pull the lead (s) off and have the volt meter set to DC. You should read at least 12vdc across the leads. If you start it up with both leads attach take a reading off the post at idle you should have at least 13 to 14 volts. If you don't then it could be a ground or your alternator if you rev the engine and the voltage doesn't increase then it's even more likely to be your alternator/regulator.
Volt meter will only identify circuits that currently have voltage, not indicate how much flow (amps) are being drawn on the circuit. For example, a radio clock draws full battery voltage but not many amps. You're looking for amps. Looking at voltage will keep you searching for many hours on circuits that are perfectly ok..... the drain time of a battery depends on cca, rca rating and health at its present state.........
Wow... Here is a much simpler way to do this:
Look just get in a dark place, pull the negative terminal off the battery, then touch it to the battery post. If you see a spark you are pulling current.
Now ONE AT A TIME pull each fuse from the fuse box and touch the cable to the post again. When you finally get NO spark you will have found the circuit that is causing the drain. From that pont it's a matter of tracing out that circuit to see where the short is. It could be corrosion somewhere, insulation rubbed off a wire, or something wired to always hot that should be wired to only on when key on.
If your neighbor knows how to use the meter, ask him if it will measure current, and get him to help you. If the meter will measure current then you can put the meter in line just like you did and you can see just how much current is being pulled.
Good luck!
Mental1,,,Your post is about random as you can get. The problem is drain not how much voltage is my alternator producing.
Ohm's Law defines the relationships between power, voltage, current, and resistance. One ohm is the resistance value through which one volt will maintain a current of one ampere.
Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps.
Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts.
Resistance determines how much current will flow through a component. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow. A very low resistance allows a large amount of current to flow. Resistance is measured in ohms.
Power is the amount of current times the voltage level at a given point measured in wattage or watts.
Since we are being picky ;)
Current only flows on the surface of a conductor when the frequency is high. In DC circuits current flows through out the conductor.
Just saying...
kjsdlk
I know it's not the alternator because it will charge the battery back up if I drive it often. I turned the voltmeter to the 10A setting like I read in another thread and got the reading 0.06. So I am not sure what that means. From what I am hearing I think I am doing it wrong? I have a cb wired directly to the battery and when I pulled that wire from the battery I got a reading of 0.03. That just seems small to me but like I said I dont know much about electronics. I trickle charged the battery (optima red top) last night and the voltage was 14.3 this morning which I belive is a full charge correct? I will see what it is when I get home after work. If it is my CB, I heard that it sucks to hook it up through the ignition because of interference?
If you set the switch to 10A did you also move the leads to the Amp position when you got the reading?
0.03 amps (30 milliamps) is not very much current at all. Think of a bright LED. It would take many days to run a battery down with that little bit of current. Double check the 10A setting and move the leads into the right holes to measure current.
Run the CB through a key switched relay. That way you are going straight to the battery to keep noise down but the ket switch controls the relay.
Verification of a full charge
It is possible to verify if the batteries are fully charged. Charge the battery. Then remove the surface charge by waiting for 24 hours. If you don't feel like sitting around for that long, turn on all your electrical stuff in the vehicle for 3 minutes, turn them off , and wait 5 minutes. The voltage of a fully charged battery is 13.20 at 25 C
afdasd
I pluged the red wire from the voltmeter into the plug that I read in another thread. I am not sure what it is. It takes a long time for the battery to die so I figure that it is that small draw. I was just wanting to verify that could kill it. It is 0.06 when the CB is connected. So that is 60 milliamps correct. And I guess there are 1000 milliamps in an amp?
Thanks, s
Thanks, s
Yes a 60 milliamp draw will kill a battery eventually. How long does it actually take? Yes 1000milliamps = 1 amp
Consider installing a simple battery cut-off switch. Or one of those automatic battery disconnect devices that disconnect the battery when it's voltage drops below a pre-set amount.
my 75 would do the same thing? dead battery inside 2-3 days and not being wiring inclined i opted for the battery shut off switch works great problem solved. mounted switch inside cab= handy.
Good luck!
Hey @Coolerman,
Been a while. My PO wired my tail lights and blinkers hot. I can turn the blinkers on, step on the brakes with the key off (radio too). Has anyone used a battery turn off? I use that on my other car, and will research a switch.
I don't have a garage at the moment so cannot put a battery tender on it which would be fine.. Battery is dying after 3 days of no start.
Thanks
My 55 does not have a battery drain problem because it does not have a radio. It is as original as it was in 1977. When the ignition is off, everything is off. It can sit for weeks and will start.
I have a battery disconnect on my 40 because I installed a radio and the clock stays on. Yup, a radio alone will drain the battery after a few days. If I start it every few days, it is ok but let it sit and I have to charge the battery.
Another solution is a trickle charger. It keeps the battery charged. Cheap Harbor Freight for $6 when on sale or more expensive ones if you want to spend more for a better product.
There are a lot of Battery Switches available, I use THIS ONE on 44. I’ve used several others over the years, but like the heavy duty nature of this one... seems rugged... like 44.
Sanctioned racing requires you break the battery positive. But, I only run 44 in unsanctioned races. :cool:
So, I prefer breakIng the battery negative cable... you will need an appropriate length of battery cable, for the second leg on the switch.
For breaking the negative, run the negative cable, from negative post to switch, additional battery cable from 2nd leg of switch to oem PS frame location.
Thanks
I carry a good jump box, when I’m out in 44. But, I prefer a charged battery, to save the hassle of jumpstarting.
There are many different Solar Tender available. I carry THIS 18W SOLAR TENDER and keep it plugged into 44’s battery, while camping or hiking.
I can mount it inside the passenger window or windshield and aim it S-SW and lock it inside.
As long as tbe battery is fully charged, this tender will keep the battery fcharged
Perfect, thanks.
