Battery Charging Light flicker/ Alternator issues?
Los Angeles
Hello,
I have been having a issue with battery charge light coming on and off randomly, started about two months ago. Pepboys Mechanic tested on two occasions the alt and said it was good; however when he tested it, the light was off. They said it was fine but recommended a new belt and tensioner. still the problem persists. Pepboys said they will replace the alternator with no charge for labor; I will buy a denso alt from dealer but I just want to ensure this is the cause. What else might be the issue? The grounds and battery terminal look good and the battery is new from lexus.
Any advice?
Probably the brushes are failing. New brushes are dirt cheap compared to a new alternator. The OEM Denso rebuild is the only one reliably know to last. My first Ultima from Oreilly's fail in a year, and I'm about to hit 2 years on the warrantied replacement. If this one fails, I'll be biting the bullet and buying a Reman Denso from Toyota.
What is your mileage? Brushes seems to last somewhere between 150 and 200k on average.
FWIW, my original alternator made it to ~250k miles. When it started failing it was intermittent. It passed 2 out of 3 alternator tests performed by auto shops. The one it failed was after removal from the vehicle.
That was 3 years ago and I just now had that replacement alternator fail again. I'm replacing with a Duralast Gold from Autozone, which they claim to be 100% new. We'll see...
I have purchased the remanufactuered denso from Lexus. I got the 130 amp vs 100 amp. It was actually cheaper than the price Toyota gave me. I will post back if this doesn’t solve the charge light issue
Well just had the alternator replaced with a denso from dealer and the issue persists. Driving home from Pepboys the light started to flicker again. Any thoughts on what else it could be. I’m working down the line to figure it out
Check all your ground connections, clean your battery terminals and clamps.
I have cleaned both ground connections and cleaned terminals. Is there anything else that could cause the discharge light to come on?
Yes- the battery. How old is the battery? How many CCA is it delivering compared to its rating? One bad cell can create these issues but still have enough voltage/capacity to allow the engine to operate.
Ok it’s a newish battery from Lexus dealer. 4 year warranty. Do you think it could cause a charge light to come on randomly? When I try turning on all electronics (ac, radio) nothing happens. The light comes on randomly even when no accessories running
Denso reman can be had for around 250$ which is a bit lower than the Toyota one, which is the same thing.
A bad battery can kill an alternator, slowly or quickly so have that battery checked as well.
This makes me think, is it possible your old battery was going bad and killed the alternator? And then once you changed to the interstate things started working again? A failing battery can draw an large amount of power from the alt and kill it quickly. Just a thought
I suppose. The old battery is a 6 year old Sears Die Hard Platinum AGM. It tested at 80+% capacity on the parts store guy's on-vehicle tester.
Check the voltage (engine running) right at your battery. See if you are getting 13.5-14.2 volts (or thereabouts). If you do...then your alternator is working correctly.
Next....disconnect the leads on the battery and leave them off for a couple of hours. Then check the 'resting' voltage of your battery. You should have at least 12.2-12.4 volts.
IF that checks out have your battery 'load tested'.
IF that passes then look to your dash panel, it is not unheard of to have a short in the printed circuit where the bulb itself resides.
