Baking Soda Blaster
Central Valley, CA
I know this has been posted around before but I happened to be in a Harbor Freight and saw this blaster. I had made my own and had great results but for $20 had to give this one a shot.
The red reservoir is the soda holder.
I made a blaster too just like his first pix but my compressor stank and I couldn't do much.
A baking soda blaster is the way to go imo for a clean/natural, cheap alternative to glass beads or sand blasting.
I keep everything under the hood wiped down with Meguiars Natural Shine Protectant. It seems to do well and is greaseless so dirt doesn't stick to it, the carb above is one I picked up as part of an intake/exhaust purchase.
I might try the soda blaster out. Im looking for a cheap blaster(also small due to garage size) but do not having a way to coat the metal without taking it somewhere.
In my humidity I would see flash rust on the surface within a few days. Ive tried with some success spraying rattle can clear coat on a part after it takes a bath in rust dissolver like evaporust.
I might try finding the wipes as well. thanks
When it was humid here, raining outside, I had some problems with the soda clogging up the gravity feed. Fairly easy fix by blowing air into the nozzle while holding the hopper lid down but it did get annoying.
Have you ever used the POR-15 products? I have had excellent results putting it on rusty metal.
I've got por in small cans I was planning on using on some area like under body, axle housing and frame.
I've seen some people blast the little metal parts and have them recoated professionally
I'll look when I get home tonight but I've seen many threads in 40 fourm with people having coating professionally done. Didn't know if someone might have a home version of coating them but I know little about the process
