bad wheel bearings?
Bakersfield, Ca
Was rotating my tires and noticed front left had movement when grabbed at 12-6. Pulled it apart and the adjusting nuts were loose. Tightened them properly and now I'm getting a vibration/shake once I get up to around 35 that wasn't there before
How do I tell if the bearings need to be replaced, anything I should look at?
Go 20 ft/lbs on the inner nut and 46 ft/lbs on the outer nut.
I used this method
Tighten the inner nut to 45 lbs/ft, rotate, back off and repeat, then just until you feel resistance. Install the lock washer, then torque the outer nut to 45 lbs/ft.
I use a torque wrench for Cruisers because you need to use the socket. It's easy to get carried away with a 1/2 ratchet.
With cars and trailers I use a pair of channel locks. I've found that I get better feel for the pre-load torque.
The rear bearings do require the special alien landing ship tool.
I actually purchased an inexpensive tool that measures the pull force (I think it was $10.00 on amazon). Combined that with the proper torque values - all as per the FSM - it was a good piece of mind for me.
Regarding your question - it wouldn't surprise me that your bearings are out of spec after having the hub wobbling around for a period of time!
Tighten the inner nut tight 50 ft/lbs then back off. This forces the thrust bearing into the race.
Now Back that nut off till loose.
Re-tighten same nut using just your hand and 54mm socket, turning hard enough to not crush an apple.
If your in doubt about the apple go in the house and grab one. You eat one every day; right?
Now install the Tabbed Washer and second nut and 45 ft/lbs.
It's not super scientific, but it works.
Is the lock washer that goes between the two nuts Toyota only or can I get it somewhere else?
@beno
I'm obviously not Beno, but there are many sources for the lock washer.
Pull 'em & check 'em.
You've re-torqued already, didn't fix.
You could try that again, this time take the outer bearing out and check it for obvious failure.
But the original observation was probably a good indication there's something amiss, and you'll likely need to fix it for sure anyway.
Odds are it's been loose so long that you may have spun a race in the hub.
Pull it apart, inspect and rebuild properly.
So I cannot source 90215-42025?
News to me considering I have maybe 200 sitting at my house.
The quote was originally directed to you. I was meaning that i'm not Beno, there are many other sources. Sorry for the confusion. I just edited my original reply.
That did sound bad, and I obviously had no personal knowledge of you not having them.
I just read another thread on mud about the proper way to set the pre load on "new wheel bearings". They said to torque the first nut to 43 foot pounds. Turn the hub three complete turns in each direction. Then Loosen the first nut, then re tighten it to 48 INCH POUNDS, not foot pounds. Then Install the star washer, and tighten the second nut to 47 foot pounds.
Front Axle Cheatsheet
