I just assumed the CV ends were the same and the shaft was simply longer on the tundra parts, but they likely would have used the same boot if that were the case. So yeah, maybe there are differences in the ends and this is responsible for your prior leak.Size, I assume, since we know the CVs are longer. I don't know how much different they are or how much it matters, but the Tundra/Sequoia is a different part # from the 200. If they are *slightly* wider diameter it would explain why the re-boot that was done on mine years ago was initially leaking grease. (Worm clamps resolved it though)
Even the front shocks are different despite being interchangeable.. with the cruiser parts being clearly heavier duty. Maybe the CVs are the same story
Edit: or maybe the longer shaft needs a larger diameter to reduce twisting
