BACON
Any of you guys made your own bacon?
Wondering if there's a foolproof recipe.
I realised after being in USA earlier in the year, Aussie bacon is very different.
It's mostly sold in a fully cooked state so it's safe from liver fluke parasite.
It completely changes the texture and flavour.
I've found one brand that does small vacuum packs of raw bacon, but it's not awesome, and is expensive for what it is
Yep, I tinker in a little bit of curing and smoking.
I would have to dig up my recipe but basically the routine is the same, brine, dry, smoke... enjoy.
My secret to arguable the 2nd greatest thing ever made after the wheel, is that I use celery juice in my brine mix. I've recently started playing with a little juniper too, and chuck in plenty of garlic. I typically use 3 sugars, white, brown and maple syrup. I originally had plans to ho nitrate free, but then I started reading up about botulism poisoning and neurotoxins, and it sounds pretty crook. The issue isn't any bugs in the pork meat, ironically its the garlic cloves. You can't sanitise the garlic clove from the dirt bugs, and that ends up in the brine. So I half the typical amount of nitrate, but the celery juice contains a lot of nitrate to balance it out.
(Often "nitrate feee" bacon just contains celery juice, so its no healthier for you).
Next comes the curing. My first few batches I cheated and hot smoked the bacon. It worked a treat, and its pretty fail safe. But its not a real bacon. So now I hang my bacon in a curing chamber and shed about 20-30% of the moisture which takes between 7-14 days. Every day I put it into my cold smoking chamber and hit it with about an hr of cold smoke. Depending on the ambient weather you dont want to do long cold smoke days otherwise it will dry too fast. If I was better setup, I would cold smoke at high humidity....
(hmmmm, no no I dont need another project)
Once you drop to around 70% moisture, its fairly stable by that point and ready to eat. One problem with making bacon is you end up with about 2kg of bacon, and it takes so damn good that you end up eating about 2kg of bacon. It does freeze fine, but Ive found you lose a lot of the naunce of the smoke profile after freezing.
That's probably enough of a info dump for now. I should start a curing and smallgoods thread so we can share more experience.
Replying to an ancient thread.
I do loads of dry cured meat.
Here is my bacon recipe.
Sea Salt1.80%30.69
Cure #10.25%4.26
Sugar (white/brown)1.25%21.31
Juniper Berries0.50%8.53
Garlic Powder1.00%17.05
Black Pepper
0.20%​
3.41
I do not use any sugar. Salt content was 3% I do not like it that salty. Put this formula in a spread sheet. Weight the belly the cure amounts will self-populate. Get two scales a large one for meat and a jewelry scale for the salt etc. Scale should go at least two decimal points. Rub belly thoroughly with salt etc. I vac seal mine a zippy can be used. Vac seal is better. Let cure for 20 days flipping bag every day or two. I vac seal and do this occasionally a zippy will require flipping. I cold smoke for about 30hrs. You can hot smoke until internal temp is 145* You can pm me and I will send you my spread sheet.
Sea Salt1.80%30.69
Cure #10.25%4.26
Black Pepper
0.20%​
3.41
Looks fantastic!
Ingredient portions are percentage of meat weight I take it?
Everyone reaches a point in their curing, when they buy a slicer to cut their meats up perfectly. Much like owning a Landcruiser, the more you learn, the more you learn that you need more things/toys to plug those gaps in consistency/reliability.
Cured meat is a similar hobby. I went from an old fridge for my cure cabinet to a huge true fridge. A double door beast.
I miss seeing this thread bumped by @FLATU8ER. RIP Jim!
On topic.
Anyone got a favourite bacon they buy in USA?
Have had some good stuff, some disapointing stuff, and some terrible!
I swear the pack I opened this morning was strips of lard that they forgot to trim the pesky little straps off meat off.
****ing 80%+ fat!
Jowl bacon. Just a big slab of baconified pig cheek. I find it at farm stands / farmers markets and occasionally at the grocery store. Slice as thick or thin as you like.
I find strips of belly bacon to be rather pedestrian anymore.
