Back Up Light Switch
Kentucky
Hello again. I've searched the FAQs for help, but I couldn't find anything to use as guidance...so...here goes:
I just ordered a used back-up light switch from cruiserparts. I installed it last night, hooked up juice and put the tranny in reverse (3-speed on floor.) I put the meter to the wire coming out of the switch and got nothing.
Is there any way to test whether the switch is good when it is uninstalled? Could it be something other than the switch being bad? Any other ideas?
Thanks.
Joel
Did you check the lead for ground, I think all its switches is ground.
Continuity test
to check the switch, put a multimeter across the switch terminals. (switch disconnected from the truck wiring)
It should read a very low resistance when *activated* (in reverse if still in the transmission or pushed with your thumb when out.... although it takes a lot of force to push it! :D)
if it's bad it will read open, or a high resistance, or all over the place like mine did.
If it's not the switch it's your wiring, which wouldn't be a suprise on a 40....
IIRC there should be 12v coming from (through) your reverse lights to the one switch terminal, and the other should be grounded to the frame.
Anyone?
(this is bad as I just totally redid my harness a while back and should really remember this!!! :rolleyes: )
Mine has a hot 12v wire going in and a switched coming out.
But the continuity test is valid either way.
Ed
OK, the switch appears to be working, kinda. I have a 3 on the floor. Now, the reverse light comes on in neutral and in 1st and 3rd (with the stick down.) When I put it in reverse and 2nd, the light goes off. Any ideas? Thanks.
What side of the shift plate is the backup light switch on? Front, or back?
Uh, Oh......never thought of that:D Can you install it backwards?
Ed
That sounds correct. Perhaps you have the backup switch for a 4 speed instead of a 3 speed in there (I don't know if it would fit. What the heck, I'm a column shift guy: :D)
I don't think they will interchange, but they work the same. You can't really hook it up backwards as it makes no difference....therefore....I have no idea what the problem is. Helpful guy that I am:)
Column shift reverse switch is under the dash, right Dave?
Ed
I appreciate you thoughts, anyway, guys. I'm also confused about how, with the "H" configuration of the 3-speed, the switch would "know" to come on when in reverse, but not in 2nd. Oh well. Thanks again!
Ed
Under the hood, actually. Ubolts into place on the steering column.
Unless something in there is bent or in the wrong slot or there's a something extra in there, it should ONLY line up with the switch when in reverse.
Column shift reverse switch for the curious....:D
are you positive the reverse light turns off in 2nd?!?
just thinking that you seem to be saying the reverse lights only turn *OFF* when actually IN reverse....
If this is the case, we have a wiring issue (unless the switch is wrong and normally closed/grounded????)
The hole is on the backside of the tower, and it is offset to the passenger side of the center point. Since the switch is also below the pivot point in the tower, it should be activated when the upper part of the lever is in the opposite position to the switch location, i.e. forward and to the left.
Now I have seen some pretty sloppy towers, and some pretty sloppy pivot pins in the towers that have allowed for quite a bit of rotational freeplay. Perhaps that is letting the lower part of the lever hit the switch differently than normal.
Does your shift lever have any rotational freeplay?
Another thought. Did you install the washer that goes between the shift tower and the switch. Perhaps if the switch were installed without a washer, it would go further into the tower, increasing the chances of making contact with the lower part of the shift lever in other positions.
Last thought. Does your shift tower have a formal 'boss' on it for the switch, a raised surface specifically for the switch. I have seen a few shift towers over the year that were cast without any provision for a backup switch. If someone drilled into one of those towers to try and retro fit it for a switch, it could cause a problem very much like what you are experiencing. For starters, they would probably move the hole closer to the center in order to take advantage of a more 'level' surface to drill and tap.
Hope this helps
Mark A.
