Back Up Light Switch
I think there's more to it than stick slop. He says the light comes ON in 1st and 3rd (Stick BACK)!
Just a thought here, but are the brake light switches(open unless released) the same size as the backup switch(normally open unless depressed)?:confused:
Does your shift lever have any rotational freeplay?
Another thought. Did you install the washer that goes between the shift tower and the switch?
Last thought. Does your shift tower have a formal 'boss' on it for the switch, a raised surface specifically for the switch?
Mark A.
Mark,
Great questions.
1. There is no rotational play in the shift lever.
2. There was and is NO washer between the tower and the switch. I'll look on Specter for what size that needs to be.
3. I'm not sure if there is a formal boss for the switch. If this is any clue, there was no reverse light on the truck (stock) nor had the screw holes been drilled for it. The hole for the light itself was there though. I'll check and send pics.
Joel
Pictures of the back-up light switch housing
Here is a pic of the switch and tower. As it turns out, my tower does have a housing for the back-up light switch, so I guess that rules out the possibility that it was drilled too high and too centered into the tower...too bad, I thought that was the culprit.
