Back-up light connection
Florida
LCers,
One of the wires disconnected from my back-up sensor on the transmission. Is this s solder "able" connection or do I have to replace the switch? I know it works and will give it a try but wondering if anyone has had to do this before.
Boaf
Its a straight solder and the wire connection terminals (there are two posts on the switch)
work in either direction. Basically its just a compression switch in the transmission that
gets depressed when the gear is in reverse. When it gets depressed then the circuit
is complete and the rear light goes on.
Thanks for the explanation, the wire looked like it went inside (there is no rubber boot over it). Will try to solder shortly.
Boaf
Don’t mean to HJ, but I’m pulling my truck back together after a clutch job and didn’t mark those connections at disassembly so I was worried about crossing wires. Sounds like I can just reconnect without worrying about it.
That is correct. The two wires coming off the switch can be attached either way. The switch closes the circuit when the tranny is shifted into reverse, sending power to the backup light.
Here's what a new switch looks like. Notice the terminals are exactly the same. No differentiation
and the wire is marked red with the blue stripe. Do not ask me
why I have a new switch and what happened to my old one. I don't want to talk about it. :\
