Build Back in a GX470 (Ferg's vehicle ADD continues)
Are you still using this setup? Can you confirm/deny that the rear A/C controls are still operational with this? I've read that controllers sourced from Australia make the rear seat A/C inoperable. I live in the desert and my dogs need the breeze.
If you set the climate control from the PRADO 120 to the GX470, the rear air conditioner will not work 100%. the front air conditioner can only be activated for 2003-2004(you need to cut some wires and attach them to the mass) , if you set the climate from PRADO 120 to GX470 2005-2009, the front and rear air conditioners will not work when you press the A/C 100% button. different wiring diagram and different command goes over the IEBUS AVC LAN bus, so the air conditioner clutch under the hood does not turn on when you press the A/C button.
if anyone needs an armrest and console from the PRADO 120 in a complete set, I can find it and send it to youm (used parts). you will pay for the delivery yourself. and I can also find climate control for the 2003-04-2005 GX470.
WhatsApp Telegram: +77082820333 Eldar.
Almaty, Kazakhstan.
if anyone needs an armrest and console from the PRADO 120 in a complete set, I can find it and send it to you. the price will be about$ 200 (used parts). you will pay for the delivery yourself. and I can also find climate control for the 2003-04-2005 GX470.
WhatsApp +77082820333 Eldar.
Almaty, Kazakhstan.
My build sticker shows 02/05. I would absolutely be interested in climate control for GX470 if my back seat A/C would remain functional. Is this something you can source or would it be a Prado 120 control? If they are true Lexus controls, I might be willing to pick up a few and help out a few of us over here in the US.
As @ZIDCONPRO mentioned, the rear controls for the GX do not function with the front Prado controls.
Almaty, Kazakhstan.
Are you able to obtain the field monitor?
I sell climate control designed only for the GX470, so that the front and rear air conditioner works.
what do you mean, I don't quite understand about the monitor?
I recommend this radio for GX470, I installed one for myself. Supports voice control of the radio in English/Arab/Russian. For the GX470, you need to select option B, so that the seller puts a CANbus to activate the mark Levinson amplifier. also included with the radio is an HD rear-view camera.
you can insert a SIM card into your 4G Internet device, or enable a wi-fi hotspot on your iphone.
TEYES SPRO Car Radio Multimedia no 2 din android 8,1 8.1 Video Player Navigation GPS For Toyota LAND CRUISER Prado 120 2003-2009
overview in English
Ok, I can find such a trip computer with a compass for you, the price will be$ 270, + delivery of about$ 40 to America. I will have it in my hands for 3 weeks if you need it?
yes please let me know. Thanks. I just sent you message on WhatsApp.
Trip computer prado 120, cover and center speaker Mark Levinson
Finished installing the Prado 120 field monitor (and new side trim). Was really not a terribly complicated install. I could do it again in prob under 2 hours, even less with something better than a razor blade to cut the dash. :p
The only real issue with these in a GX470 (besides cutting the dash) is that they are [currently] stuck in Celsius temperature, and if you have a ML sound system with middle dash speaker, the field monitor cannot fit with the stock speaker and it must either be removed or replaced with something smaller/thinner.
I am still messing with mine to see if I can get it to switch to F degrees, but I also wonder if not, if there is a version that is available from another area where they would use F degrees and had the Prado 120 available with the field monitor. Seems there is really only a few countries that *might* fit this description....
Some stuff I have already gotten to switch from kms to miles and m to ft. I'll keep messing though and post up more details.
View this thread, starting on Post #35 for more detail on my Field Monitor swap: Prado 120 Gauge Cluster Swap Into GX?
20190101_144755-jpg.1867925
A better shot of the Field Monitor display:
Hi! how could you switch mileage to miles on this trip computer?
With engine not running, If you hold buttons down for a few seconds, it goes to settings mode and allows you to cycle through each display type and some can change units. This is how i got mine to change.. It didn't help for the temp display--that one was still stuck in Celsius.
This user manual might also help: http://www.toyota.senkai.ru/ruk_prado.html
