I did not know that. I want to swap my H41 for an H55 in my 78 40 and will need to modify the transmission tunnel. I don't have the H55 yet, just trying to gather parts. I'm open to suggestions folks. Thanks.
Which H55F? You a running a V8 or stock 2F. There are options in 60 series inspection covers and 40 series inspection covers.
View attachment 3353095View attachment 3353096View attachment 3353097
Which setup your is will help determine how to proceed. There are OEM options of mounting and aftermarket. OEM are harder to find. Not sure on cost of either currently. I located OEM bits before prices started going crazy.
Pictures with the white and red covers are 60 series. The white started 10/82 until 11/84 or 4/85 depending on the market it's from. 10/82 is the starting date for the H55F and the cover reflects the taller H55F transmission. Both four and fives used this cover. Same with the next generation but are harder to find because on the FJ62 this part is a direct fit when switching to a H55F. The two on the left in the first picture are a 10/82+ five speed on top a four speed on the bottom. This are raised as well because the H55F was being used in some markets. The transfer case shifter opening is the only difference. The five speed opening a little further back. The 60 series transfer case opening for the shifter is further forward. That because the shift tower on the 60 series H55F top cover is further back. With a V8 the 60 series cover is close to the original four speed location. 40 series places the transmission shifter in the stock location. With a V8 will be like conversions you see with the transmission shifter under the heater.
I would buy and get the H55F installed including the shifters before working about modifying the transmission cover. There are a lot of options how to go about the conversion. How you end up will determine what is the best way to modify the transmission cover. But if I had a 83 FJ40 would be searching for H55F that would bolt directly in. Occasionally packages like this show up.bought this one but have seen others.I plan on modifying the tunnel and was hoping to make it look half decent with one of the 60 covers. Will know more when I have the transmission.
Bj40,bj42,hzj75 trans tunnel plate
US$60 each plus shipping
