axles?
What? Front and rear axles are not interchangeable whatsoever.
Wait, I can’t use the front shafts in the back?
May be different on a full-float rear end, but the F and R shafts on a standard, US spec FJ60 are not interchangeable.
Rears have the hubs permanently attached and are cut for C-clips on the diff side... fronts are shorter, splined on both ends, no C-clip at the diff, and pop into the birfields on the outer end.
Edit: (unless you were being facetious...then, my bad)
- Brian
- Brian
I was joking.. good on you for sharing info though!
