axle swap
You might want to define a little more where you are at in the process and what exactly you are having trouble with. Do you have the axle yet??? did you get one w/ a locker while you were at it? What year is the new axle. The brakes really should go on in similar fashion to how the old ones came off. Are you replacing just the housing or whole shebang disc to disc and everything in between?
the LSPV is in both years, but I know the 97 have ABS...non-issue since you don't have the controller. You should just be able to fab up the hard lines to be in the right place above/below each other and run a new braided line to the housing. I am not sure if the booster will have enough to push the rear calipers though???
LSPV = Load sensing proportioning valve.
jcj_78FJ40 brings up a good point- the FF axle takes 16" wheels. 15's won't fit, if you were planning on using your stock wheels.
-Spike
I did this same swap except mine was a 96 axle. I switched to 16" rims so I don't know if 15" will clear. Other posts suggest not. I was able to take my stock 92 brake lines and rebend them to work. I have 35" tires and the pedal is a bit soft but I can lock them up with hard braking. I am bypassing the LSPV now and I am going to install a manual proportioning valve. This way I can adjust the front to back bias for on or off road. You will also need to change the parking brake cable. I made some durlon plugs to replace the ABS sensors.
Everything else was a direct swap. :cheers:
You would be grinding the caliper. I know some people have done that with some 15" wheels, but I don't think they were the stock aluminum ones. You can't grind the caliper too much.
-Spike
You shouldn't probably need 1.5" spacers. You could probably get away with .75 or 1" spacers. I would go with the least amount of spacer that you could. I ran 2.5" backspaced on my 94 with 15x8 steel wheels and they cleared. From looking at them 3" backspacing would do it. But each wheel has a different lip.
The LSPV becomes a problem. Summit racing sells manual PV and the metric adapters.
You will need the Ebrake cable from a 93-97 with DB as it is a little longer.
