I want to hear more about the 9.5/60 combo. Which 60 outers are you using?Ok, front - 9.5 housing with dana 60 outers on 38's bias ply measures 11.25, rarely rubs
rear - dana 60 measures 11.25 and will prolly get to 11.4 next season, rubs a bit more.
Remind me- RS 9.5 will h what steering knuckles?This is an interesting metric. We know not all 40s are equal, but close enough to have an idea for the most part.
This is a RuffStuff 9.5 on 40s
Mine has Hellfires on itRemind me- RS 9.5 will h what steering knuckles?
I want everyone to feel good about themselvesWhy do the inches look longer on Patricks tape ???
I wonder if you’d do the KP today with all the SD parts available? I’m not sure I have my head fully wrapped around the hybrid 9.5/60 possibilities. Is it possible to use the RS 9.5 housing and the SD 05 outers. I think there’s a compatibility issues with the 32 spline shafts…Archie, I used stock kingpin inner C's off ebay, Reid ( Dedenbear) Knuckles, GM 30 spline stuff outside of knuckle , CTM's, custom 4340 inners ( 30 spline ), made seals inside tube at knuckle like Toyota has. Uses 86' K5 stuff for brakes. The inners were the most expensive, like 840 bucks in 2002. The knuckles were a steal, got em on ebay for 350. The CTM's were pricey but Black friday didnt exist back then.
You built that axle in the last year, correct? The hellfires aren’t currently available from RS. Is it a matter of being patient until they do another run?Mine has Hellfires on it
One can also put in a Gearworks 10" diff in a 9" housing. Lot of racers doing that too. I am not sure how many are running actual 9"? Either way, much better than a toy 9.5" Pinion shaft diameter comes into play, and support, 3 bearings, not just ring gear size.SD is 35 spline. If you are going to spend the money. Don’t try and cheap out when building a custom axle . Trust me you will kick your self for doing so . Yes you can use SD c and Knuckles on a RS housing . The RS housing uses 3.5 inch tubes. If you are dead set on having to use Toyota stuff for what ever reason. I was myself also once upon a time . Then get a tundra diff 36 spline and 80 balls . I have a RS housing with Tundra diff and. Can show you that diff compared to a 9.5 .
. If you want the ultimate in strength and clearance. Go with a 9 inch diff and 60 outers . ( what most ultra 4 cars run ) I believe my diff is rated to 1000hp and 40 inch tires . If you plan to go bigger than 40s say 43s and up go straight to a 14 bolt and shave it . And run 40spline .
Yeah I called them and waited for some to become available. All money in with everything, I'm just building 609s next and moving my current axles to another projectYou built that axle in the last year, correct? The hellfires aren’t currently available from RS. Is it a matter of being patient until they do another run?
