axle rebuild? (pics inside)
hey guys,
could this be the common axle rebuild i need to do to fix my problem? driver's side brakes prematurely wore out fast, i replaced both the rotors/caliper and pads.
since then (maybe prior too) i've noticed that there has been a good amount of grease/oil has been leaking out and a clunking sound has been heard when i turn (to the left?). i haven't driven the car but am curious what i need to get to replace/fix this problem.
thanks for any help/insight
Yep . Looks like it is time to rebuild. You at least need new seals, but with the clunking sound you might need to look at your birfields.
Yep, classic front axle repack needed. Check out the FAQ tips and images - especially understand whats leaking is not the seals you can see there on the sphere, but a tiny inner axle seal that must be replaced.
DougM
alrighty thanks guys.. i'll order all the parts from CruiserDan? does he have the parts for the birfs too? is it a good idea to do the birfs as well while i'm doing this job? i dont know how much more work/expenses there is with the birfs.
now do i have to do BOTH passenger and drivers' side or just the drivers' side?
I would wait and see what condition the birf's are in before replacing. Although it never hurts to have some as a spare, so if you buy some then realize you dont need them you will be that much farther ahead, in the long run.
Front axle repack and I wouldn't do the birfs unless they look real bad.
Set aside along weekend, have lots of brake cleaner and paper towel and wear clothes you dont want anymore.
Bext to do a complete tear down one day, clean the small parts and let the birf/axle sit over neat in degreaser and then start fresh the next day putting it back together.
Lots of steering arm bolts loose, dont forget the step that talks about tighten the 4 bolts, hit the steering arm with a hammer (up) tighten some more. Check toruqe values after 500 miles
I just did the job this weekend, it was not hard just cleaning
things for hours, go to the carwash first and use degreaser and a brush, check that, order the parts from CDAN. Parts are cheaper
and every piece is enclosed. He is a true asset to this website.
I did not clean anything first, the carwash would have saved me a bunch of time and Scott towels. MESSY!!!
George:beer:
thanks guys..
97, did you do the wheel bearings, drive flanges and birfs? Cdan just gave me a quote and if i did everything it was going to add up a lot!
what are the likely hood that i need to get all three or should i just take everything out first and see?
I also just finished this up last weekend. The FAQ write-up is great! It doesn't hurt to have the FSM by your side, but the FAQ is very detailed. Its dirty, but managable. My '92 has over 200,000 on the clock, and I was able to reuse the wheel bearings and birfs. I replaced all of the seals, and ordered from CDan.
-TT
-TT
good to know! did yours look like mine at all? did it have any clunking sound?
I just got done doing my axle rebuild a few weeks ago as well. It wasn't hard, just time consuming. I had a clicking issue prior to the rebuild. I thought that repacking the hubs, with new bearings, seals and all would/might take care of the problem. Now, the leaking is fixed but the clicking is still there. I will have to redo about 1/2 of the job over. This time, I'll be replacing both birfs. I'm not saying that you have to replace your birfs, but if money is not an issue, it would be a good idea to do them, and keep your old ones as spares as mentioned by millatruse. Take your time. Who cares if it takes you longer than expected. Just as long as you get it done right the first time. Don't take shortcuts.
BTW, I repalced all gaskets, all wheel bearings, all trunion bearings, both drive flanges/plates, all seals, and whatever else CDAN recommended. My brake pads and rotors were still okay so I skipped those.
guys, it could possibly NOT be the axle seal/bearings. i haven't had time to take it apart and access the damage yet. but i had a mechanic look over it really quick and he said it was the steering arm knuckle and quoted me about $800-1000 including parts and labor. is it something you can do it yourself and if so how much more work is it, than to rebuild the axle seals,etc?
i had a problem with my key earlier and i read on here that people yanked the wheel back and forth hard to solve the problem.
long story short that is the most idiotic thing i could have done and remembering, i think it was this that caused this leak/problem.
thanks for any input/help
no, I think it is more likely the 305,000 miles of driving that caused this problem.
The mechanic is talking about the same thing. there is a great write up in the faq.
bhm- which write up is it that y ou're referring to? the axle/birfs?? i don't see a steering knuckle arm thread in the faq?
believe me, i wish i knew i didn't do it.. but i yanked it so hard that i heard a couple things POP and afterwards my friend said she saw something drip from under the car :(
i hope it's just not worse than what i think/imagine it is!
but isn't this front axle rebuild, different than the steering knuckle issue?
no, it is the same thing. the procedure in the faq includes replacing all of the seals in the steering knuckle including the inner axle seal. Most people on here will recommend doing this maint. every 60,000 miles at most so you can feel confident that turning the steering wheel didn't cause the leak, it is just normal wear. Mine was just as bad when I bought the truck at 195K. The job is easy, just messy and time consuming.
ok guys i've actually started on this fix and gotten most of the things off. i just need to take the axle/birfs out. it seems like it's stuck. i think i might have not done all the steps but soon will.
you need to do the steps on BOTH sides right? the passenger side doesn't look bad at all.
