axle not going in??
slc area
Had diffs regeared to 4.88 and now I can't get the long side (DS) back in. WTF?? Just rebuilt the front axle about 5-6 months ago, 1500 miles or so ago. Yes, I made sure the diff was locked before I pulled the axles. Are there any ancient chinese secrets to get the splines aligned???
Front or rear? In the front you just have to keep working it as it will tend to angle downward. There are a few ancient secrets, don't knwo them off the top of my head. Have you tried FAQ?
Rear should be straight forward. Don't know what that could be.
On my first one I had some difficulty getting it together, just took patience. Now I put both loose axles (no birfield attached) into the axle tube before reassembly to make sure I won't have difficulty installing the assembled axle when it's time to put it all back together. Got a loose axle handy? Maybe a local has a spare they could lend you?
-Spike
index finger under inner axle inside the axle cup, beyond the birfield. push up as you push in to keep the axle straight....
Pull it out, rotate 180 degrees, try again.
This is what worked for me after about a half hour of frustration:rolleyes: Thanks for the replies.
