Axle housing
Guu
Groote Eylandt
Hey Guys, I've found a 60 series out bush with only a 159k Kms on it. Will this axle housing fit my 1985 FJ73 ??
I'd swap my diff and axles & everything from the fj73 into the 60 series axle cause the one on my 70 is bent.
6X series axle is wider than the 7X series. diff offset is slightly different as well. don't think it's what you're needing...
Blast ok. So really i need a leaf sprung 7x axle housing to ensure a like for like replacemeny
YES. the 40 and 55 series are the same width as your 70, but prolly too old in other ways to want to use. I know that the 70 series stuff can be put under the 40 and 55, but you prolly don't want drums and coarse splines under your getter...
other option would be to outboard your frame side spring drops to match the extra width of the 60 series housing...but that sounds like work to me. GL HTH
  • Like
Reactions: Guu
