I'd get OEM boot kit, if you' like to replace included measured amount of CV bearing lube.What de-greaser should be used? Im thinking of just pulling the boots back, spray de-greaser, grease the joints and pull boots back over. And use @pfran42 clamp kit i bought.
Can of degreaser from NAPA, high pressure water, high pressure air and then lube & boot before rust has a change to start.
Best practice: Replace differential to axle snap ring and oil seal, along with wheel hub flange to axle snap ring.
IIRC: Point diff to axle snap ring opening (gap) down during front drive shaft installation.
