Axle and birf fitting
Qld
Hello
I have some new axle and cvs I am putting in and the new axle is slightly longer (7mm)
My cruiser is late 1995 and from what I've read as it's after early 94 it should have the longer one from factory.
What am I getting wrong here?
The manual hub lock won't fully seat
Cheers
The cv birf is the same size as mine I took out but the axle shaft seems to be 7mm longer
It appears you have the longer CV joint (246.5mm) so it's likely that the stub shaft of your CV joints need a second groove for the snap ring machined into the shaft.
So far I have found that the free wheeling hub seats perfectly and functions LOCK and FREE without this circlip installed. The circuit was on the car when I installed it and now the free wheel seems to hit it and leave a gap.
Is this clip really necessary or do I have to take the axle out, and shave 7mm off the total distance of the shaft on the diff side?
This is very frustrating as I need the car drivable tonight and I am considering leaving this circlip off and bolting the free wheel hub selector back without it.
Any help appreciated
From post #21 in the thread/link above/below:
@OGBeno :
"Shorter 80 series birf (4/1994 and earlier: PN: 43405-60120)= 238.5mm
Longer 80 series birf (4/1994 and later: PN: 43405-60070)=246.5mm
You can buy two new earlier birfs (no ABS ring--came stock on 1991-1992 rigs) or you can machine a snapring groove on the later birfs.
Birf snap ring groove width=3mm
New snapring groove on longer birf should start 13mm from the top of the birf."
Hey Kernal just seen your reply. That sounds exactly what's happening.
So from this I'm trying to figure out what has happened, and what I need to do. Do I have the wrong birfields for my late 1995 model. And to do now I have to machine an edge deeper into the hub for the circlip to seat deeper down just like the image you posted.
For a short term solution now, if I leave the circlip out and drive with the hubs unlocked obviously, is this going to cause any issues until I can remove and replace my old birf, and take the new ones to a machinist to get the deeper circlip added.
Appreciate the advice mate
Thank OGBeno
Nah your a legend mate, gave me the exact answer I needed right in time. Appreciate the guidance to Benos post. Everything back together now and on road. I have removed the axle from both birfs and on way to a lathe for the groove to be cut.
Have a great day mate. 🤙🤙
