Axel vents?
ppillard said:
So I guess no one really knows for sure about putting vacuum on your axles via a snorkel?
as the air filter dirties, it will begin to look for the least path of resistance, and that may eventually be pulling in enuf pressure from the diffs to cause problems....additionally, that small draw on the seals MAY be enuf to pull in water during a crossing, definitely bad for the diffs.
There is a recent discussion in Hardcore about pressurizing the axles....
I used to run vent tubes up to the glove box and then thru fuel filters. Now, only automatic tranny is open vented, both diffs and the t-case use accordian boots.
I got the breathers from Mark. Thanks Mark!
fit perfect, no tapping or rethreading.
Rear axle was under pressure. Turns out the vent wasn't venting!
released lots of air when I took off the original vent.
Glad I did this before Rubithon.
Just need to tie in the transfercase vent now.
Hi,
i've put breathers on my rear diff and T-case so far, i'm yet to do the front diff and steering box, but since i haven't driven my 55 offroad yet i guess it's no rush.
my rear diff breather goes up to roof height just behing the rear right hand door, inside the pillar, with a fuel filter on the end.
for the front diff, steering box and t-case i will run them together onto the firewall, with a filter.
as for taking it to roof height, i doubt that it needs to be that high, but if water does manage to get in there, im sure i would be worrying about a lot more than my diff oil :D
Cheers, Dan.
BushBoy said:
Hi,
Cheers, Dan.
Considering the way FJ55 roofs take on water, I don't think I would mount a breather there! :D
Seriously, why not up inside the rear side panels?
Bodean said:
I just popped the caps off of the vents and ran fuel line up into the cab (back) and fire wall in the front. Has worked for years. And yes you need the vents. Water doesn't like 90 wt.
Later,
Ditto. Been working like this on multiple trucks for many years.
