Average time to replace a head gasket?
Colorado
Looks I'll be joining the ranks of the head gasket failure club.
I heard some "leaking air" sounds near my radiator cap and saw that the overflow tank had a pretty steady flow of bubbles coming up. Antifreeze also smells like exhaust gases instead of antifreeze.
The truck did not over heat so I think I caught it in time.
What is the average time to replace a head gasket for a moderately skilled shade tree mechanic with all the necessary tools?
In looking at other posts, it appears that you can pull back the intake manifold and exhaust manifolds without removing them entirely from the vehicle.
Any other tips you'd offer up?
Thanks,
Adam
Get the video from Doug on here. Its supossed to be really good and have all the little tricks and what not thats not in the fsm. Also dont know what your budget is on this but I had my mechanic quote me for doing a head gasket and it was $1700.00 thats labor and having the head machined I was going to provide the factory HG though
The pisser is that I had planned on scrapping this engine this coming winter. It has an annoying vibration between 2400 and 3200 rpms and just under 250,000 miles.
I'm suppose to be in Moab at the end of the month and two weeks isn't enough time to ramp up my engine change out plans to a diesel.
I hate to dump money into something I know I'm not keeping, but I don't have much choice if I want to attend Moab.
I'll probably have the head checked just for grins and valve seals replaced. I assume CDan is the best bet for gasket kit.
Thanks,
Adam
Adam
I think it can be pulled apart in a long day (10-12hrs) and replaced in slightly shorter. Shorter/faster if you're a bit experienced, have a helper, or complete set of air tools. Of course you'll have a few days down time for the shop to do the valve job/seals/pressure test. Unless you have these guys near me that provide same day service. All this assumes you don't find a part missing on assembly, which means Cdan is your man for a complete proper kit.
DougM
Great. Thanks.
I've done a few re-builds and head gaskets on other vehicles, but not on a LC yet.
I'm looking for a head shop to do the work in the local area and will order the gasket set on Monday.
Adam
Mine took 2 weeks.
1 day to tear it down, the head shop was backed up so they had it for 10 days (weekend included) then a day to put it back together.
Mountain high perfromance in Wheatridge, next to ATS Bill and pat have been doing all my heads for years.
303-420-6218
Adam - I am shopping this around right now. Dealer says that the repair manual calls for 10.5 hours total. That seemed really low to me. Most Indys are quoting me between 12 and 14 hrs labor - not including machining. Estimates range from 1600 - 1800 without ANY add-ons that make sense to tackle after she is unzipped.
I'll keep track of my hours and post the results.
Adam
In an effort to prove to myself that head gasket is really blown, I rigged up a pressure gauge to the radiator and discovered that my cap is only holding about 2 lbs of pressure. I pulled the cap off the wife's 100 series and I didn't see any bubbles in the overflow after letting it idle and heat up. Since temps were below freezing, I put some cardborad in front of the radiator and pressures topped out at about 10lbs. I pulled the card board and ran around the block and it was still in the 9-10lb range.
I'll run down and get the sniffer test of the antifreeze done tomorrow just to be sure.
Adam
Scrap it and get a new engine. No sense in polishing a turd or throwing good money after bad. Just take your wifes 100 to Moab and when you get there, ride along with someone.
I went ahead and replaced the head gasket. It took 7 hours to get it off and about 13 to put it all back together. There were several hours of cleaning as well. This engine/vehicle came with a layer of grime that needed removal.
The gasket was just starting to fail on the #6 cylinder. It may have lasted a while longer, but I'm glad it's out and the vehicle is running well. I also replaced all of the vacuum hoses and my fluctuating idle issue has disappeared.
I did this job on the cheap, just the cost of a CDan valve grind gasket kit and a lot of brake cleaner. I also took the head and intake to the car wash and hit them with the pressure washer. They all cleaned up very nice.
One issue that concerned me is that my valve clearances where very tight. .0010 on the exhaust and .006 - .008 on the intake. The book calls for .0025 and .0015 respectively.
I found no evidence of this engine ever being opened up before and it runs fine now. Either they have always been this tight or they loosened up after the valve train was bathed in oil again.
Adam R.
