Auto up window mod issue
Brevard, NC
I performed landtank's auto up window mod last night. It works, but not every time. It seems like it's not releasing the command to lower or rise. And I can hear the motor making noises after the window completed it's up or down (but the window doesn't move). And now my alarm is going off after I lock it. I just disconnected the switches until I figure this out.
I like the mod - I hate to yank it out. Any thoughts on this? Did I do a poor soldering job and it's shorting to another spot on the board? Anyone else experience this?
You seem to contradict yourself here
My guess is the diode is in backwards. Or you have a big solder glob shorting a few traces togetherv
Hey - thank landtank. How did I contradict myself? I guess in that it works but it doesn't always works.
So I can auto roll it down. When I go to auto roll it up, it waits a few seconds, then it works. But if I try to go back down, it sometimes will and sometimes won't. This morning, I was pulling into the parking garage at work, so my XM was off. Very quiet and I could hear the actuator clicking on and off. The window was not moving. I didn't have time to test it but it seemed that when it was clicking, the window would not take a command. I apologize if this isn't clear.
When I originally soldered this in and plugged it up for the first time, I smell burning. I soldered the diode in with some length left on the diode and just bent it over. I though it was probably touching the board causing a short, so I put some electrical tape under it to isolate it.
I believe I have the diode in correctly. The stripe in towards the drivers window switch. I'll try to add an image link below.
https://goo.gl/photos/Apym4NQpAQ2cHirm7
And closeup from the side.
https://goo.gl/photos/ate3FVbMDYATC8nJ9
And I want to thank you both for your initial post and for your ongoing help. I really do appreciate it.
Update: I rechecked the solders. I then bent the diode the other direction so it had less to possibly interfere with (so it's not over the board anymore.) One of the solders appeared to come up a little, so i redid them both - just to be sure. I also put the tape down to isolate the diode so it wouldn't interfere with anything else.
I just checked it in the truck with the same result: It first appears to work correctly - Regular down and auto down works as it always did. Regular up works the same as well. It's when I use auto up the problem starts. It goes up, but then I hear these clicking sounds inside the door (after the window is up.) Actually, it's about 2 seconds after the window is up, I hear a kind of a whine sound. Then a few clicks. It will not roll down again unless I auto down twice. it's like the first auto down releases the auto up command and the second one actually rolls it down. Once I press auto down the second time, it waits about 2 seconds then it goes down. Then the cycle is all messed up. Then auto down finishes and I have to wait to go back up. One time it went about 3/4 up, stopped, waiting about 2 second, then continued up to close.
I would love your help in making this mod work, but if not, I'll just remove it and go back to the way it was. Again, thank you for your help.
Ok...I am a newb here and honestly feel really uncomfortable doing this but I have have to say that I am really shocked at your responses landtank.
:rolleyes:- I read the entire post and have to say I am not sure where this is coming from. A recommendation was made based on the limited information supplied, seemed like the most probable thing to recheck, i.e. The non oem part added to the system. In the absence of better info. Once the OP mentions smelling something burn I think removing the mod to prevent a fire or further damage seems prudent advice.
The mod isn't working, the links to his photos aren't working for me and he smelled something burning.
What would you have me suggest?
I read every single thing EXCEPT......that he smelled something burning. Without that little tidbit it appeared that you were saying something else. It was late and I even stated how uncomfortable I was because I didn't want to make a mistake but alas...I still managed to look like an ass. I am truly sorry and deleted my post.
Oh man - I didn't mean to cause confusion but it appears I did just that. I guess somewhere between the 5 month old daughter, work, projects, and just plain poor communication skills... I think I've been told that... along with my poor listening skills.
It only smelled the burning the first time I put it in without tape behind it. I think the diode was touching the board. I have it in the truck right now and, as long as I don't use the auto up function, the window works as before. No burning smell. Just auto down only and regular up and down.
But I guess I'll have to pull it. Maybe I'll try another diode (I bought extra 4001s) and I think I'll try it with a shorter wire - reduce the possibility of shorting and remove the need for tape. But I think I'll wait to try this on my other 80 until I get this one right.
Again - my sincere apologies for the confusion. I alone created it.
If I could just drive up to MA, I'd buy you a few blondes (beers) to apologize properly.
No no...while I appreciate you guys letting me off the hook, I created the problem by not reading all of the info.
It looks like you have accidentally joined two terminals. The one on the right leg of the diode with the one below it.
see pics here: Auto Up Window Mod
I'll all good, brother. You are just trying to help. And that's appreciated. No issues.
Man - I wish you were right, but it doesn't look like it. But I think I'll just replace this one anyway.
Well, I tried another diode. This time I trimmed it down, took the solder out of the holes, placed the wires through the holes and soldered them in place. The test was exactly the same: Regular up and down are fine. Auto down is fine. But once you try auto up, it gets stuck in auto up and will not disengage. Regular down will not work at this point. You have to engage auto down. The window then sits for about a second or two, then goes all the way down. I guess I'll just remove the mod. Too bad. I kinda enjoyed this one.
Last attempt didn't work. Removed mod and back to stock. Everything works as before. I appreciate the help. I mean - I got the Radio Shack 1N4001 diode (1a, 50v). I don't understand. But at least my alarm won't go off on it's own again (waking up the little one.)
Thanks again - this forum is the best.
Well, I removed the mod but I wonder if I messed up the board. With it back to stock, up is giving me trouble. Down and auto down work fine. But once down, it doesn't want to go up sometimes. I can hold it and it will eventually go up, but it sits there for a while first. I wonder if I burn something up the first time when I had the long leads - I assume the diode was touching the board when it was smelling. That was stupid on my part.
