Auto Climate Blower Motor No Speeds
Chattanooga TN
Ok I hope many of you are getting ready for GSMTR at Windrock this week:)...My Collectors Edition of course has the Auto Climate just like the LX450...No blower speeds. Yes I have Have replaced the Resistor, swapped the amplifier with a buddys LX as with the Transitor...still not enough amps or volts to the plug that goes to the blower...hooked the blower to a 12V supply...it blows good. Also have swapped out the AC Brain amplifier above the gas pedal...no change...all functions work on the control panel, all my relays seem to be clicking behind the glove box and in the drivers kick panel...I understand the blower operates based on the level of ground coming from the main plug...Ive read every post here on the topic...What else do I need to check or do here? Im at a dead end:bang:
Not sure this will solve it, but have you tried switching over to Manual visa the switch on back of the control unit?
I've not had to troubleshoot this system on my '97 CE but since I'm also in Chattanooga if you ever want to do side by side voltage/component comparisons of components let me know.
Hey thank you I might take you up on that
Well I figured it out...even though the relays were clicking and sounded like they were working...it turned out to be the black relay in the divers kick panel...thanks for everybody's attempts to help
