Straight from the engineers. Thought I would post this so that if someone did a search they would have a little more info. The people at offroadlockers have been very helpful.
Marshal,
Here are some thoughts from our engineers on thrust washers and thicknesses. Sorry it took a while. As they note replacing a worn cross shaft is critical, and if you are within tolerances with the existing thrust washers then you do not need to replace them. I felt that since your diff had over 100,000 miles on it, you would see some wear that might put you outside of the tolerance window.
Many vehicle manufacturers have a variety of thrust washer thicknesses.
Although there is often what is regarded as a standard thickness - for a
notional new differential - there are usually a range of thicknesses so
that a worn differential (worn planetary gears) can be "shimmed" back
into a resonable condition to remove excessive backlash.
So there will always be a dilemma - Since the locker dimensions are
based on a notional diff - usually near new then the notiaonal new
replacement thrust washer would be fine except where a diff is really
badly worn and then the thicker thrust washers would be required, but
you would not know this in advance.
So buying them could be a waste of time as the right thickness may not
be known until the installer has inserted the locker gears ionto the
case and taken a measurement
Having said all of this - I would be much more inclined to suggest that
someone replace the cross shaft in a very old vehicle as this is what is
quite critical to operation.
Once again - until inspected you might not know and I might also add the
average user would not realy know how to inspect it for wear and doesnt
necessarilyhave any accurate way pf measuring it to see if it is worn.
Wear on diameter of more than a few of thou is good reason to change it.
The issue is what is the spacing between the cams.
>> You cant determine this until the parts have been partially installed.
>> I am assuming that the reason the new thrust washers were required is
>> the spacing was out of spec ?
>> With teeth engaged and parts installed into the diff the spacing
>> should be around 0.145" to say 0.165"
>> (no need to install springs and pins - just so you can slip a set of
>> feeler guages in between the cams)
>> This can be achieved without removing the differential case from the
>> bearings or removing the crown wheel with this vehicle.
>> So whatever thrust washers yield this measurement are the ones that
>> he needs to get
>> The way I do it, is either install the parts without thrust washers
>> and measure the intercam gap. Then take away from this measurement
>> say 0.155" divide by two and that is the thickness of each individual
>> thrust washer. This will yield a gap opf 0.155" which is middle of
>> the road.
Marshal,
>> he needs to get
>> the road.
