Aussie install issue
South Mississippi
I am trying to install my Aussie locker but I can't get the damn differential cover off. I removed the 10 bolts around it but it's stuck on.
Any tips on how to remove it?
Tried a screwdriver/hammer combo and all I did was flatten the head of my favorite screwdriver :(
Next step after that will be a cutting torch
What about if you use your floor/bottle jack and if you can find a metal wedge of some sort you can use it to pry the cover off from below with the wedge on the jack. If you go slow it could pop off.. ...
I will look into that, I gave up for the night but will get an early start tomorrow.
I was under the impression that I need to remove the c clips which are holding the axels in there.
1. Fill differential with ether starting fluid through the fill hole.
2. Stand back.
3. Toss lit match into fill hole.
:D
This method might be a little hard on the seals.
Why not just black powder? Much more effective :doh:
I am just going to try and bang it off tomorrow, if that doesn't work may weld a hook to it and pull it off with my Pathfinder.
The one advantage to a semi vs. full float is we don't have to remove the tires or third member which usually is 1/2 of the work.
No worries, I wasn't real specific on what year I was working on.
