Attach Snow plow: legality
Tokyo, Japan
Ok, I found this 80 for sale on Yahoo Japan. It comes with a snow plow that attaches to what seems to be a stock damage multiplier...
Q1: Are these snow plows available in the states?
Q2: Is it legal to drive with one on public American roads?
Q3: Wouldn't it be great to clear the neighborhood roadways? Instant hero?
I would love to hook one of those up to my ARB and clear my sidewalks and driveway, while maintaining the off-road-ability when removed.
I don't think you need a special permit. You see them all over the northern states in the winter.
I've never heard of any state requiring anything special... My job is driving a plow truck in Montana and no special permits are required here.
I've never seen that brand before but... I've never been to Japan either :p. I'd have to see more pics closer up of that plow before I had an opinion.
the larger/better known brands (atleast around here) for smaller plows are Meyer's, Western, Boss, and Fisher (more of an east coast company).
Hey there plowman. I assume the brands you mentioned require a special hook up. I've seen them on Ford's I think, but is there a way to put them on an 80? The 80 is so much more capable than an F150, it would be great.
No permit required. No license required.
The one in the pic looks like a hydraulic unit. For simplicity's sake, I would think an electric one would be an easier fab. I doubt that bracketry is available in the US for an 80.
FWIW, I used to plow for about 2yrs (just two winters) here in Michigan with a Dodge 3/4 ton 4wd. Let's just say that plowing is "tough" on vehicles. I wouldn't suggest it for an 80 if you plan on keeping it for regular driver duties. The dodge was my DD, and had to be replaced after two seasons for frame twist, bracketry cracks, etc...
my $0.00002
There looks to be a regular plow mount below the front bumper. I doubt it has anything to do with the damage multiplier. Most of the plow mounts I have seen on trucks would make offroading nearly impossible since they hang down very low.
Perkins: the only thing that is special about the plows are the vehicle specific mounting brackets (usually). These mounting points are just different shapes/sizes to accomodate different frame widths/sizes
uberhahn has a very good point... plowing can be VERY hard on a vehicle.
If I remember, or you hound me I can get some pics of our trucks so you can see how they mount up. Its actually quite simple and really doesn't hang that low... just kills the approach angle.
:cheers:
-Jesse
I don't think I'd ever consider plowing snow with an 80 either. I may be wrong but I think you'd be out a transmission pretty quickly. I think that's a chore best left to a super duty P/U with a diesel .02
For the average guy who just wants to plow his driveway and a few of his neighbors almost any vehicle is going to be suitable, I have a 82" SnowBear blade mounted on a beater 4Runner that has no ill effects after 2 years of personal use.
It is setup to be able to be removed or installed on the vehicle in under 5 minutes so traveling with it on the vehicle is not an issue.
If the plow is for a commercial use, then you would probably want a commercial vehicle (heavy-duty PU etc.), but for a personal use, I don't think the vehicle is as important. It will obviously wear on the vehicle more, but not nearly as much as if it were used commercially. I have seen Wranglers with plows, and a few 40's with plows as well. Probably not the best idea if your looking to make $$$! Just my .02
-TT
wranglers and fj40's can fit in alot tighter places (turning radius is key) than alot of commercial setups so they work good for driveways and the like. The City here uses a few old jeeps to do wide sidewalks and park area's.
if you run into alot of things like curbs, boulders, frozen snow banks, or other hidden suprises you obviously start to beat things up including yourself :p.... steering wheels generally aren't soft. I've discovered numerous treasures hidden in the snow. Tranny's seem to die because someone works beyond the capability of the truck and/or plow BUT...
In the end for personal use you shouldn't see much more wear and tear as long as you are smart and safe about how you move snow.
after all it is a landcruiser right?
:beer:
-Jesse
Thanks Jasonmt you really made it clear to see how these things hook up. I didn't know you can put one on any vehicle with vehicle specific mounting brackets. But this was just the first 80 I've seen with one. I guess it would put a lot of pressure on a drive train with back force on the components. Frame twist?! YIKES! Well I did recently see a video of a train having trouble plowing.
That's a lot of mass and engine power:popcorn::
LiveLeak.com - Train plow vs Snow
And one where the train wins :popcorn::
LiveLeak.com - Train wins this time
I agree with the other posts here already.....for PERSONAL use like a driveway or two, almost any "truck" would be fine. But for commercial type plowing or any plowing that you're doing on unfamiliar property (more likely to hit hidden obstructions) you need a 3/4 ton pickup or similar, in my opinion.
And my opinion is based on plowing commercially for 6 years. It is NOT easy on a vehicle. In fact, I think its one of the most severe tasks you can subject a truck to and it needs to be built to take it. I plowed with a 3/4 ton 4x4 Dodge pickup with a factory snow plow prep package.
Unless you've done it, its hard to visualize the stresses placed on the truck plowing snow. Snow is HEAVY! Go lift a shovel full of wet snow and then think of how heavy 200 shovel fulls at the same time would be. Almost everthing on the truck is stressed...the obvious being the transmission & frame. But i've seen 1/2 ton 4x4 pickups with sagging, trashed front suspensions just from driving around with all that weight hanging off the front end. Just my .02....
Unless you've done it, its hard to visualize the stresses placed on the truck plowing snow. ....
Never done it, but I've visualized it. Turk's in WI plowed with a 3/4 cab blazer, I was out at his place one day and the front windshield was smashed. He hit a concrete barrier of some sort while plowing comercially. Hit so hard it smashed the windshield. Doesn't take much to imagine what that force did to the truck between the plow and the windshield
I had a snowplow business in Bozeman MT for a couple years. (I did a bunch of lots out by Dick Walter... big sky racks and that area, and some around 4 corners) IMO a fj40 with power steering is about the best vehicle you can have for small commercial plowing. They are much much more manouverable than a typical landscaper truck. Better quality than the cj5 I had before. With my plow I could usually make about $200/hr which was more than most of the other plow guys I knew could get out of a full size. The reason is that I did mostly small commercial lots and I could clear them in about 1/3 or so less time than a full size rig. If your doing it for money, speed is the key. Your best $ is between 4:00 and 7:00 am. Thats the prime time if you will, and the more you can do in that window the more you will make. I prefer a 3 speed for plowing as its directly forward and back. Plowing lots involves a lot of backing and forth and turning around. Short vehcles are the answer. If your doing roads, then you would want a lot bigger truck and the key is how much width you can plow in a single pass.
Also, if your doing it for profit "wings" are an absolute must. They go on the outside of the plow blade and usually angle forward about 30*. The good ones are spring loaded, adjustable angle, and use rubber outer edges so you can scoop curbs clear. They scoop snow better and significanly increase efficiency. Especialy by keeping the little spill over at a minimum. Of course this doesn't apply with a V plow.
I think an 80 would be a great plow rig. Especially one with lockers. Heavy, good low end torque, reasonably short wheel base, durable, strong auto tranny, and good visibility.
What plow did you have on your 40?
