Arrgg!! Park Break Leaking Again!
Southwest, MO
Ok guys, what did I :censor: up here? I got the park break kit from cool cruisers, used everything but the round seal/gasket, because the one in there looked perfect, didn't see and scoring or wear.
If that part is the one that causes this, what do i need to take the old one out with? It seemed pretty tight to me. It does seam to be on the outside of the plate, not inside now.
Also putting in a pic of driver front brake/axle. What is leak from?
Change the seal....
Distort it with a flat tip screwdriver....and pry it out.
Inner axle seal on the front axle is leaking gear oil into the knuckle that should have Moly grease in it and not oil.
Do I need to replace the seal in the axle? What is the proper thing to do there?
FYI-
That little rubber piece is to be on the outside, not the inside...it seats into that radial groove behind the 10mm head on the adjuster...
In order to replace the inner axle seals in the front, you will need to tear apart the front axle from the wheel bearings inward.
If you do not have a FSM, get one.
It is not difficult, just a mess.
Good luck!
-Steve
FYI-
Good luck!
-Steve
Thanks for the tip on the rubber piece. It didn't have one on it when I started, so I took a guess.
What is FSM short for? Rookie here:idea:
Is it just me? or is there a gap between the backing plate and the rear brg. retainer housing?
Should there be a gasket of some type there? There wasn't one there, and the haynes manual didn't say there was either that I can remember.
There is not a gasket for this mating surface.
If the seal is not seated properly in the housing (flush) it can create this situation...
