- Thread starter
- #21
lowtideride said:Oh heck no, Its a part time case from a fj62
Is this with the A440 tranny?
alkaline747trio said:That is what the drop bracket for 6" lift consists of, except it's a 4" drop w/ CC bushings. And the price is $373 + 25ish shipping VS. $515 + 50ish shipping, so more like a $150 difference.
alkaline747trio said:Is this with the A440 tranny?
Nay said:You need 36" tires then a 4" mount drop is not a good solution, especially for that kind of coin.
For $130 or so plus shipping you can get 5 degree caster bushings out of Oz. Check ebay.
Nay
-Spike- said:Pinion angle, not caster, determines whether or not you need a CV driveshaft. With a 6" lift at near the correct caster, you will most likely need a CV shaft.
-Spike
alkaline747trio said:Those only MIGHT put my caster to where I wouldn't need a CV drive shaft, and definatly wouldn't put the axle where it needs to be for minimal trimming.
alkaline747trio said:The thing is, at 4-5" of lift, if you over correct for caster a certain amount, then you can run your stock drive shaft, or I was led to believe, which is why I want to correct for 6" of lift because that is what the slee arms are for, and that is what Ben @ SOR said would keep me from having to run a CV shaft.
If brackets w/ CC bushings will do the same thing as the arms and not be as much of a compromise as everyone is led to believe, then that is what I would run. If not, then tell me that the brackets will absolutly positively not work, and I have to run the arms.
I guess what I am trying to accomplish is correct for caster, not need a CV drive shaft, not have to trim a whole lot for 36's, and not break the bank doing this. Does this mean the Slee arms are my only option, or does that mean the brackets and CC bushings will do all that, just with a slight compromise in clearance and possibly flex?
lowtideride said:Your divin me nuts;p do some labor, save some money. Like 500 dollars.
Nay said:Of course, you want to run 36's for hardcore wheeling on an 80, and $500 for caster is going to be the least of it, and that's the real problem: wanting to run 36's on a big lift on a practically non-existent budget![]()
Nay
sleeoffroad said:The arms are the new ones. It was mentioned in this thread
https://forum.ih8mud.com/showthread.php?t=104310
