armor basics
Below Da Bridge
I was curious about the most vulnerable areas on the 80-Where should I put armor first? I'm on a limited budget (aren't we all?) so I need to know what to protect first. I'll be wheeling on muddy rocks.
Dave
Rocker panels...get some sliders installed first. The long wheel base on these make the rockers extremely suceptable to damage.
The only other damage I have done to mine is the front OEM bumper. Its all beat to :censor:...an ARB is on the wish list.
I have also replaced my back bumper (still in progress). See link in my sig line. I removed the OEM receiver and gained several inches of clearance in the back.
If vitals are most important then transfer case skid plate. Slee makes one for less than $200 IIRC and I know IPOR has one as well.
ARB front bumper with the A/C condensor protection plate add on from Slee to protect that little puppy and sliders.
1. Sliders
2. Transfer case skid
3. front bumper
4. rear bumper
My preference is to begin with sliders because they are the first point-of-contact when things get rough, and fixing crushed rockers is expensive. If you're lucky you can lightly crush a rocker and ignore it, but more commonly it affects the lower door edge and does entail seeing a body shop. When an 80 meets an immovable object it rarely results in 'lightly' crushing something... In hindsight, sliders will seem cheap and easy.
For vitals, the factory transfer case skidplate is a joke and should be replaced with aftermarket.
Bumpers are last on my list because you can wait until you start to play hard enough that you damage them. True, you may incur body damage at the same time, but overall an 80 can go pretty deep with factory bumpers. I prioritize the front bumper over the rear because that protects me, personally, moreso than the rear.
Once you add sliders and bumpers you will need to address the coils because that much weight will compromise the stock suspension.
but everyone's needs are different based on geography and how they intend to use the rig.
Once you decide where to start you also get to embark on the incredibly time consumptive process of choosing which brand you like the most.... it's a fun process, but get ready to spend a couple days on mud!
Definitely sliders first. If you wreck the bumpers after installing the sliders then you have a great excuse to get the ARB or slee bumpers. As some people have already said, once you hurt the rocker panels, fixing it is always expensive and sometimes impossible.
Sliders first! x100...
X 3.14
like everyone has said, bumpers if they get trashed...no biggie, throw on some ARB/SLee/4x4labs/hanna/TJM/Kaymar/makeyourown bumpers and be done.
You should try pricing out replacement rocker panels. :eek:
You have solidrock off road, Metal Tech, Slee, Hannah, etc to choose from.
I really like the Metal TEch sliders on my 80, nice design, beefy.
Protect your transfer case first. It's the lowest hanging part underneath, besides the diffs.
You can still drive home if you trash your rockers, but if smack the T-case one time to many, you're walking home.
If you've got a factory/aftermarket hitch, I wouldn't worry to much about the rear bumper. That hitch will take most of the abuse.
X 3.14
x5.29! I know he said he's not worried about cosmetic damage, but not being able to open your doors is a little beyond cosmetic...
The hitch takes the abuse...but it hits every freakin thing on the trail...its only allows about 14-16" of clearance...and when the vehicle is raised in the front, even less.
IMO, its more of a hinderance than its worth. I removed my hitch and cut the frame 2.5" and installed my own (still in fabrication stage) rear bumper. Hardly ever hit it on things unless dropping off a ledge, and due to what I made it out of, never does any damage.
I would agree with those who said to get a rear bumper before the front. It is easier to see where the front is going than it is look behind you. It is also possible to steer the front away from things. The rear is locked in its tracks. The rear of the 80 seems really wide when trying to squeeze through tight trails. The body panels behind the rear wheels need protection that only an aftermarket bumper can give, especially down low.
David Sword
