Are shims enough
Yuma az
ok so i have a 4 inch hell creek lift and about another 1inch lift on a shackels
so a total about 5 in and no doubt it vibrates like a mother &%$#
so i installed some shims and was wonderin if that would do the job
or am i goin to have to do somethin to the other side of the drve shaft
it vibrates in 2wd at about 25mph and up
and for sure its becasue of the lift cause i had it for ten years and just lifted it
i put the shims in the rear cause when i eye ball it the rear looks like it needs it
i corrected the pinion angles back to original using the shims
so i was just wonderin if its enough
i havent put it all back together yet
Turn on recording... "Check driveshaft phasing"... turn off recording. ;)
Mark...
Mark...
LOL!
Just add it to your sig line already!
Mark...
Good call.
Did you take your shaft apart?
attachment.php
From: https://forum.ih8mud.com/showthread.php?t=46598
