- Joined
- Aug 23, 2007
- Threads
- 114
- Messages
- 1,114
- Location
- Kennett Square, PA
- Website
- cruisin4parts.com
I've been doing some reading and a lot of my symptoms point to a Pin 60 problem. It's consistent with the prius documents as well. I can repair or try to replace with this from Aliexpress.
My question is, are 2006 Cruisers affected by the same Pin 60 problem? I thought Toyota fixed the Pin 60 problem in 2005 after the TSB went out (see attached).
Here are the symptoms my cruiser is having:
- Shows "Audio Off" even though radio can still play, AM and FM work.
- Climate control buttons below screen are inoperable.
- Pressing CLIMATE shows the "check the connection of the air conditioner" screen
- Left side buttons barely work, non responsive or slow.
- No reverse camera
- Info screen doesn't show MPG, speed, etc.
- No outside temp or interior temp shown In that dark plastic area below the nav. Clock is visible. Security light blinks when its supposed to.
- Dash has no problems, coolant temp, etc all work.
I am aware that it may not be a PIN 60 problem, it could also be the AC Amplifier, the Gateway ECU, or a "fuse issue".
Pretty frustrating after having done a lot of AC work to get it finally blowing consistently cold. It's currently stuck on the lowest fan speed on 67*F or so.
I need the one with the B in the part number (88650-60B60)
