I would agree; sounds like a KDSS issue.TD springs and TourFlex (like OME) springs are made by King in Australia. As said above the taller spring goes to the gas tank side. TD and my TourFlex are 10-30mm longer on the tank side. I'm close to level to 1/4" off (pending customer loads) on all my spring installs. I think this would be the same for OME and Dobinson. These companies have 1000s of these spring sets out in the field. Sounds like a possible install issue with swapping springs or KDSS relief/operation during install.
Jason
I respect your work .. but 10mm is not 1.25". That is a fact not an install issue. ... Just saying.![]()
, but I would be surprised if there were mechanical / physical differences related to suspension on 2016+ models. I’ll check the FSM for part number differences to see if that may be the case.Thanks ...
I'll be triple checking things Monday for sure !
Your passenger side is low, right?
Your Driver's side is high, right?
Let's assume for the sake of discussion that you did indeed receive in spec ARB springs which are 10mm different in length.
IF, and it is just an IF until you check it, since you stated you did not see any difference in length in the ARB springs, just think about what might happen if you accidentally installed the 10mm shorter spring on the Passenger side (supposed to go on the Driver's side) and the 10mm longer spring on the Driver's side (supposed to go on the Passenger side).
The result would be a passenger side that is 10mm lower than it is supposed to be and the driver's side would be 10mm higher than it is supposed to be. Or, the driver's side would be 20mm higher than the passenger side (or, the passenger side would be 20mm lower than the driver's side).
To me, just IMHO, 20mm is almost an inch and you observed approximately 1.25 inches difference, right? I think the springs are most probably installed on the wrong sides. Switch them and check again. If still not level (or within the magically missing 0.25 inches) put your rig on a level surface, check that all tires are at exactly the same psi, open both KDSS valves 3 turns and let the rig settle for awhile.
My guess is your problem will go away.
Just my $0.02.
HTH
Just my $0.02.
HTH
They both source springs from King Springworks. Dobinson makes their own and Trail Tailor has some too.There's any easy fix for this - send the ARB springs back and get ToughDog. Problem solved.![]()
Ran the part numbers for a 2008, a 2013, and a 2016 and the OEM Toyota spring parts are the same.Not to, but I would be surprised if there were mechanical / physical differences related to suspension on 2016+ models. I’ll check the FSM for part number differences to see if that may be the case.
4813160D40 SPRING, FRONT COIL, RH
4813160D21 SPRING, FRONT COIL, LH
Interesting. I used PartSouq. I clearly defer to Gaijin.The Part #'s I found (Toyota Rear Suspension Parts):
2016 Spring, Coil, Rear Left 4823160B11
2016 Spring, Coil Rear Right 4823160A20
2013 Spring, Coil, Rear Left 4823160E21
2013 Spring, Coil Rear Right 4823160F31
2008 Spring, Coil, Rear Left 4823160E21
2008 Spring, Coil Rear Right 4823160F31
2008LC and 2013LC share the same springs, but 2016 definitely has different springs for left and right.
HTH
