arb locker question
SoCal
I'm looking at a 3rd set up with a arb but it doesn't have the wiring that comes with the locker, I've never set one up, what all do you need on top of the actual locker? From what I can understand, besides the obvious compressor and air line, I would need the switch setup and some kind of solenoid.
thanks
Aaron
The trickest setup I have seen used a OEM locker rotory switch wired to the solenoids.
http://www.geocities.com/~jjjoutside/arb.html
I am not a fan of the blue air line they come with. Braided ss line is best but spendy. So do it like the factory did the brake system. Go the distance with hard line (brake line) then use braided line at the ends. 3- 6" between the compressor so the hardine wont get flex fatigue by compressor vibe and as much as you need going to the axle. IMHO follow the stock ps brake line on the front with stock suspension arms. On a the 3 link I am going to run a hard line down the center of the upper link while I build it.
thanks, the switch is probably just a switch, does anyone know what their solenoid would cost and if I would need anything else?
Give ARB a call for the individual bits you desire. They sell small stuff direct to the general public. Blue line is fine as long as you route it properly (never broken one yet). The super duper line is good too but if there's a snag, your failure point moves to the brass hardware at the diff, which are not as easily repairable.
Good luck.
