I was up in New Hampshire for the Yankee Toys Fall Gathering and I lost the rear locker due to a blown air line. The line appeared to have melted from an exhaust leak, despite being protected by ¼” fuel line. I was able to cut the effected line and pull more air line down from a service loop of excess tubing that I keep wrapped up by the solenoids.
The point I want to make is that I needed to "steal" the right stuff to fix the air line from a generous sole on the trail as the hardware that ARB supplies is not reusable.
When I got back I wanted to make sure that doesn’t happen again, so after perusing the ARB website, I came up with a small list of parts that are now in my parts box all the time. They are so inexpensive it really doesn’t make sense to go out without them.
170601 $1.51 airline support tube
170602 $2.52 outer compression nut
170603 $1.51 5mm ferrule
170604 $3.70 central compression nut 5mm-3/16
ARB also sells a 5mm airline splice for about $10. That’s part# 170206, but I found a McMaster replacement that works well for $2.80. McMaster part# 5449K192.
Hope this helps someone.
