Get a stopwatch, activate your air locker and time how long it takes before the compressor cycles again. This is a fair indicator as to the condition of your O-rings...
Troy's symptoms were different than normal bad O-ring cases, in fact his were odd from day One. Even before the compressor was wired, it was leaking oil/air out the solenoid, so his axle had to be building up abnormal amounts of pressure on its own. Pressure build up in differentials is absolutely normal, hence why they have a vent in the first place. Now with a bigger ring gear, the mass of an Air Locker, shaved diffs, etc this problem is multiplied. Now, in Troys case, his locker worked fine, and held air to spec., even with the compact compressor (much less volume of pressurized air to diffuse air loss). His only symptom was the gear lube/air leak.
I've dealt with this in the past, just never on a brand new install, most were several years old, and likely the culprit was O-rings. In chatting with several techs (and other axle gurus here in SLC) we all came up with some theories...
1. The stock breather on the 80 is rather small, you can buy a fitting with the same thread, that has twice the diameter... I replaced the fitting, run a much larger ID hose and cleaned out the ARB pressure line. This was the most suggested culprit of all.
2. Synthetic lube, more specifically the light upper end spec stuff that was used... Troys symptom happened after it had been driven for sometime, and sat overnight. It would slowly bubble air & lube out of the solenoid even the morning after it was driven... as mentioned. The synthetic has a smaller molecule, its going to find its way out of the third under pressure, especially with a rusted OE vent...
3. Bad/twisted O-rings... As mentioned I've dealt with these over the years, and was ready to replace them if needed. Theres always the possibility that they got tweaked during install, but we did pressure test the locker prior to install, and the symtoms were not related to the compressor pressure in Troys case, so I didn't think this was too likely.
Hopefully Troys fix is permanent... if not the O-rings will get swapped out
