ARB Locker Question ?
Personally I think for the huge amount of money paid for these lockers this problem should have been rectified long ago and all ongoing probs fixed for naught.
Imagine driving off the showroom floor in a new vehicle and it pisses oil everywhere.
Fix immediatly or big problems for the dealer.
For such a large respected company I think this makes them look like a joke and they need to get there s*** wired a bit tighter or ALL air lockers will go to TJM , in Aus at least.
When installed correctly, which almost all installs are, the ARB setup is close to flawless. The pressure problem is due to the size of the Toyota diff housing, so on the initial install it doesn't take much effort to tap a larger vent hole and increase the diameter of the vent hose as you run it up out of harm's way. If one doesn't do this "extra" step on Toyota housings then pushing gear lube up the air line is a slight possibility (I don't know the percentage but I suspect it's very small, as to those who experience the lube/air line problem) when you work the lockers. I don't think Toyota is going to increase the size of their housings any and I sure wouldn't want ARB to decrease the size of their carrier, so we Toyota owners just have to adjust to the situation. They are expensive puppies but IMHO they are worth every penny just for the convenience of having lockers available at a flip of a switch and I also realize that my opinion isn't worth much.
did u main is fixing or replacing O-Ring is one of the maintenance? if i need to replace the O-Ring for the rear do i need to remove the lockers from the carriers how long it should take ?
If that question was directed at me, I would say no, as my definition of maintenance is making sure the compressor wires are wrapped and clear of any metal that could rub through and short the compressor, cleaning the grove in the compressor can and re-lubing the O-ring found there, making sure the air line is up and out of harms way and just checking the solenoid connections for any leaks if your compressor cycles every 10 minutes or so without any locker use. When I have my compressor on and don’t engage my lockers for a couple of hours my compressor never recycles during that time period unless I’m leaking at the solenoid fittings or the can.
As far as determining if something is amiss within the housing I would suggest disconnecting the air line from the housing and put your thumb over the line – if the compressor stops then the problem is very likely within the housing, if the compressor keeps running then your leak is probably somewhere forward of your thumb.
Yes, you will have to remove the ARB carrier and for the rear, that normally means a 3 to 5 hour job and as long as you’re in there you might want to replace the bearing etc. if you have a lot of miles since the install.
guys
i had replaced the Air line and breather filter its worked fine , but after i disconnect the switch after 2 3 hours their is leaking at Solenuid Valve what is mean buy this the O-Ring is holding the Locker about 7 min so its mean that its fine.
while i was testing the Arb locker and while i was reversing i heared a sound like thunking, what might be this i was at the full turns and reversing, i test it back its still fine
