ARB Locker install
I want to mount the air tank on it's side along the chassis rail. The air fittings are taken care of but I realised that I should have a drain in the bottom of the tank for removing water condensation.
I am thinking of getting one of the boilermakers at work to TIG in an 1/8"BSP bush into the tank at its lowest point so I can seal it with a 1/8" bung.
Should I also fit a one way valve in the air supply line for the tank to try and take some of the back pressure load off my compressor?
I got all the bits to hook up the compressor and tank. Hooking them up this weekend.
Hopefully I'll get my centre back tomorrow. If it doesn't turn up I might have to do a road trip to Brisbane to pick it up.
i like the install, looks great, I know you'll def. be happy with the ARB. I haven't met tooo many ppl that have ever had issues with'em, especially after ARB redesigned a couple trouble spots in them.
i'm gonna need to move to your side of the world, seems like you all get all the good stuff, HDJ's and Jim Beam & Coke in a can! Maybe i can finish up my school down there studying abroad. :D :cheers:
Certainly looks stout, now I know why I haven't heard of someone grenading the ARBs yet :)
Strength plus the ability to instantly engage the lockers:bounce::bounce2::bounce::bounce2:
Damn, I keep on forgetting to play down how good OZ is:doh:.
If I keep this up we'll have all of MUD buying all of our good cruisers. The prices will go through the roof........:idea:wait a second, maybe I can buy all the cruisers while they are cheap, then make a killing.
:flipoff2:
Centre will be delivered early Saturday morning:bounce::bounce2::bounce::bounce2:
Hopefully I'll have it on the road again by Saturday lunch time.
I still haven't got my locker in yet. After replacing the bearings I checked the contact patch on the crownwheel and found it to be wrong so I have packaged the centre up and sent it to Brisbane to get an expert set the pinion positioning shim correctly. This delay has allowed me to spend a bit more time sorting out my compressor/ reservior/ air system. I already had a compressor mounted under the bonnet that puts out more air than an ARB compressor so I am using that. It didn't come with a reservior so I am planning on mounting an old 9kg fire extinguisher on its side in between the LH chassis rail and the LH sill.
Apparently the reason I couldn't get a good contact patch was that the r & p was badly worn. Months ago the pinion nut came loose and I just replaced the seal and the nut. The time running it while it was loose must have worn a pattern on the teeth.
It really needs to have the r & p replaced but there would have been an extra wait on getting the parts. My main priority ATM is getting the vehicle off the hoist at work so the boss doesn't get too shirty.
I'm in two minds as to whether I want to regear when I replace the r & p. I'm running 285s but with the turbo diesel it doesn't feel as if it needs regearing on the highway, I'm always looking to change into sixth gear if it had one. The only reason I'd want to regear would be to get better low range gearing.
I might wait until I fit a rear airlocker and see what the rear r & p is like. It has had a loose pinion nut before too.
