ARB Locker install
Maryborough, QLD, Aust.
I'm installing a ARB front airlocker in my rig ATM and want to get some info on where the air line fitting goes exactly. Being a high pinion doesn't give much room to move.
I've searched but most of the results are from ages ago and the pics have been deleted or won't show up on the POS computer in here at the shop.
I'm taking photos of my install so will upload them later when I get home.
So who has pics or links of air line fittings on high pinion Toy diffs?
I don't have any pics but I have a link that might be usefull.
http://www.gearinstalls.com/arbinstall.htm
Thanks for the link. But that is not for a high pinion. I need the exact location for a high pinion centre.
I'm on my way over to a mates place who has a ARB in the front of his 80. He is away for work but he told me to go around and check it out. Hopefully I can get into his shed and take a look.
I've had a look at my mates 80, the dogs finally let me in:rolleyes:
I now know where the hole has to go.:bounce::bounce::bounce::bounce:
I'll take some photos of it so they are available for other mud members to look at.
Strike me pink mick, long time no hear ,you still living over on that T.U.T. thread???
Just saw this thead. The pics fro brian894x4 look very similar to mine. I have two of them, one on the 80 and one on my mini-truck, so if you need any additional pics or info let me know.
I don't know if this will help, but here's a few shots of my '89 toyota PU SAS.
My front diff is a Land Cruiser 80 high pinion with an ARB.
http://www.brian894x4.com/images/ARBfrontdiff002.jpg
http://www.brian894x4.com/images/Mods0406SAS06.jpg
Edit: Sorry I just saw that you found what you needed.
Thanks for the info guys. I was feeling a bit chicken when it came time to drill the hole. After seeing where my mate did his I took the plunge and drilled mine. I did it in the same spot as you guys.
I'll post up some pics in a little while, I just got to resize them first.
Yeah, I have been hanging out in TUT lately because I haven't had to do much wrenching on the 80, you know reliable diesels etc.;) So I haven't been straying into tech much lately. I'll be around a bit more in the next couple of months as I am prepping the 80 for a big trip in May. I'm heading out to cross the Simpson Desert, visit Lake Eyre and the Flinders Ranges and then go and spectate at the Outback Challenge http://www.outback4x4challenge.com/ at Broken Hill.
I still haven't got my locker in yet. After replacing the bearings I checked the contact patch on the crownwheel and found it to be wrong so I have packaged the centre up and sent it to Brisbane to get an expert set the pinion positioning shim correctly. This delay has allowed me to spend a bit more time sorting out my compressor/ reservior/ air system. I already had a compressor mounted under the bonnet that puts out more air than an ARB compressor so I am using that. It didn't come with a reservior so I am planning on mounting an old 9kg fire extinguisher on its side in between the LH chassis rail and the LH sill.
A couple of pics of the airline fitting in the housing.
Assembled (but not 100% complete)
Couple more
attachment.php
what is that....jim beam in a can?
It's a Jim Beam and Coke, I think. Not that I know from personal experience, I just know some guys..
Yep, Jim Beam and cola in a can. There is always a carton ( or part thereof;)) in my Engel, you know for emergency use :flipoff2:.
In OZ we can also get Jim Beam and Cola Mid Strength in a can and Beam's Choice and Dry in a can. They are also available in glass stubbies.
MMMMMMMMmmmmmmmmm...........Jim Beam.............
attachment.php
I want to mount the air tank on it's side along the chassis rail. The air fittings are taken care of but I realised that I should have a drain in the bottom of the tank for removing water condensation.
I am thinking of getting one of the boilermakers at work to TIG in an 1/8"BSP bush into the tank at its lowest point so I can seal it with a 1/8" bung.
Should I also fit a one way valve in the air supply line for the tank to try and take some of the back pressure load off my compressor?
