I have searched and found info on ARB lockers leaking at the solenoids. I have a different problem.
The arbs front and rear are a new install with only about five days of nuse. The first couple times out the rear worked fine but then it started locking part of the time. I would have to drive in reverse and it evenually would allow the compressor to stop. Now it will not lock at all and the compressor runs constantly. I can hear air escaping through the diff breather.
The front unit works fine.
Any ideas or is this a sign of the orings being installed wrong? There is no other point of air leak excet for the rear diff breather.
Thanks
Lowell
PS Also trying to find the thread that shows how to wire the locker switches so I can use the front without using the rear.
Thanks
Lowell
