ARB bumper whistle
Mine is a bit out of wack (passenger side sits higher) but no, I've not noticed that. Granted it's been mostly the same since buying the rig 5 years ago aside from being knocked around a bit while wheeling. So it's possible I just never noticed. I'm usually pretty keyed in on odd noise though.
I do have an odd whistle on acceleration but it's been there since I've had it. Checked all the usual stuff. Right after I got it I had a dealer check it and they told me it was the fan. It's never changed since then though so I haven't dug into it. Mine is def accelaration related though. Once it's cruising it only happens under more throttle.
Adding any bulky aftermarket parts like that to a vehicle will def change some air flow/sounds.
No sir. I run the ARB Deluxe with 12k Warn Tabor winch. Also I have a LED Lightbar attached to the upper antenna brackets.
Are you sure it's from the bumper? When I removed the bug deflector I had wierd noises. I replaced the rubber seal under the bonnet and the problem was solved (to mount the deflector I had to cut the seal on 2 sections.)
Yeah because I just installed the bumper and it didn't whistle before.
Did you have to mess with the fender liners during the install?
IRRC: A few guys installed the 4Runner ARB front bumper and had whistling... it ended up being the fender liners.
Might not be applicable to a LC install, but who knows.
No the arb doesn't mess with the fender. Thanks though.
I would guess the cutouts in the top for the winch and clutch lever.
Never seen the big holes right below the winch? Did you made those?
Well it's gone now. I finished the license plate mount took it on the freeway and it seems quiet. Thanks for the ideas.
I was eyeballing those 2 hinges (presuming for your plate) - I was going to suggest them as bad actors, but betting they now are bolted to the plate.
My plate rattles at ~70mph on the highway because it rattles a little ziptied to the bumper bar on my tundra, despite alot of gorrilla tape on it & bar where it touches.
Sometime I’ll drill holes & just mount it right. Sometime. (so never :hillbilly: )
Haha nice. I put some hvac foam on the back just in case it wants to rattle. Front plates are kind of a pain.
