ARB Bumper fitting problem
My ARB does not want to slide onto the frame horns, they look to be about 3/16" too far apart. I assume it got tweaked earlier in it's life. Going to take it to a body shop to have them tweak the horns in a bit instead of beating it with a sledge. Any one else run into this problem before?
3/16'' isnt much. I'd try heating up one of those frame horns with a propane torch and smacking it a few times with a sledge before going to a body shop. Worth a try at least.
3/16" might be too much to move in on your own, but you might want to first try a heavy duty ratchet type strap wrapped around both frame ends to pull them in just enough to get the bumper started.
propane torch isn't going to do anything but waste gas and give you false hope. rachet strap or come a long.
I'd figure out first whether it's the ARB or the frame...
I had the same problem. make sure you are going on dead straight. If it's cocked even the slightest bit, it won't go.
X whatever on ratchet straps around horns, and be dead straight. Mount winch now before its on (if applicable)
A bottle jack between the frame mounting points of the ARB makes quick work of it.
I used a highlift on mine, it was off about the same 3/16 on my 95. Took all of two minutes to fix, bumper slid right on after. I think a comealong would have worked just as well.
Bottle jack between bumper mounting box sections will move it out as needed but will need to be in place while it's positioned, then released. Tried it and bumper just flexes back. Probably will just go that route. I'm going to clock and mount the winch first.
Use a hoist make sure it's perfectly straight and add lube maybe hit it with a grinder on each side not much of a clearance issue
but do you actually have that sticker on your 80?
No. I do not. I put that in my sig so you all who don't know me will know that I do indeed love 80 series Land Cruisers. I like the 120 series as well but I don't love it. I had a 6MT FJ Cruiser that I loved but not as much as my 80. I love the idea of owning a 40 though the joy of owning one may be overshadowed by my 80 and how capable and comfortable it is. The 80 is the one for me.
Your 80sLC must have been into an accident before perhaps this is the result , I did install my ARB without any problem fits like a glove and all the bolts are lines up where it should be , ARB has a jig to built all their bumper exact fit to the 80s , but if you have this issue do like other said .
Also, I don't want to rain on anyone's ARB parade -- but I got a delux bullbar for my tacoma a few years back -- I think the crew that built the bumper for my taco was looking at the specs or using the jig for a silverado -- because NOTHING fit right and I had an epic customer service war with ARB all the way up to the president..... anyway -- too many garage mods, excessive grinding & elbow grease later and I got it to fit my truck. I still use ARB, just know that they aren't always spec'd the way they should be and often need to be beaten into submission.
