aquaplaning !!!
Only when I go too fast on wet roads!
All vehicles can aquaplane, just a function of waterdepth, road surface, speed, tires.
Why do you ask?
Never. I don't drive that fast. It would take quite a bit to get my tyres to hydroplane anyway.
Tires
I have a set of Bridgestone Revos on my 80 and they are fantastic in water. I have not experienced any hydroplanning. They are the best tire in water I have ever had on a car, truck, etc, period. I used to run M. LTX's but Revos RULE. Typically I put on 30-40K miles for work, and at least another 20K for pleasure road trips. Go to Tire Rack.com and see for yourself. That is why I bought them.
SS
I've found that BFG AT's are surprisingly bad in this respect.
That's a BFG feature, they ride on top of the water to reduce drag!:D :eek:
Switching to Nitto's fixed that problem.:D
Agree the Revos do well with aquaplaning. Correct tire pressures are important, as is tread depth and pattern.
DougM
I did'nt know AWD's could hydroplane?
:confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
Not to sound "stoopid" but, do you speed up when you see water of sumpthin?
I a have first hand expirience with a BFG AT set (30/9.50x15) in an inside curve semi outside, 70+ mph, water (way) deep enough to hydro, (I40, go home time, I was 20) and my comment is those Bad A;) s things were great, saved my life!
granted the contact patch and PT 4WD, but AWD, & @5,500lbs ????????
I never thought I'd hear that AT BFG's hydroplane.
if the first wheel that slips (open diffs) is the one with the least amount of traction wouldent that be the first wheel to get the power and "dig" through the water and not "ride" on top of it?
ie, "the wheel that slips is the first to grip" sound familier?
School me on your driving style
Or maybe too much air pressure.
Or maybe it is that an interlocking tread designed without water channeling in mind actually doesn't channel water well, and not channeling water well is a major factor in hydroplaning :flipoff2:
What do you expect from a tire designed in the 1980's? Just another reason that BFG AT's suck, added to the list of:
- as loud as modern MT's
- hard compound freezes in severe winter conditions leading to dramatic loss of performance as temperatures fall
- Very little perpendicular siping for hardpack/icy conditions causes unpredictable braking and lateral handling
- as expensive as MT's
Buy a modern tire if you want modern performance.
Not sure how this has anything to do with it. AWD's can hydroplane. Hydroplaning is more about speed than traction, here AWD's are at the same mercy's as 2WD's.
A heavier rig just means you have to be going a lot faster than a lighter rig.
Any tire on any vehicle will hydroplane. It's a function of the water depth, downforce and to a lesser extent tread design. There's a formula for it.
The reason there's a finite formula is that water acts like a solid when you're trying to push through it fast. Water will even stop a bullet. Even with huge downforce (think fully loaded 747) you simply cannot get water to move out from under a tire contact patch that fast. No how. No way. The speeds are lower than you think, too.
Best way to avoid loss of control on highway puddles is free. Slow down. It's also the only way - simple physics.
DougM
You must be kidding, right?
The name may be the same, but trying to say todays BFG A/T is the same as the on that came out in the 80's is like trying to say a 60 is the same as a 100 since both are called a Landcruiser.
Let's address a couple of them:
1) Loud as a MT? Haven't heard any howling from mine.
2) Hard compound. Sorry, but they don't have a hard compound, if they did, they wouldn't be one of the few tires, outside of dedicated snow tires, that qualify for the Rubber Manufactures Association Severe Snow Rating, a test that measures traction in freezing conditions.
3) I have had no problem with braking and handling and find the BFG's to be very predicable when they let go, such as trail braking to get the tail to come around (yes I do that in the 80). The older Generation BFG AT's did have some really poor handling and traction in the rain as they wore, but that went away when they went to the dual compound tread.
4) The same prices as an MT? What the hell does that have do with anything. Michelin Pilots for high performance cars run close to $300 a tire.
