Anyone runing additives in their fuel?
Wilmington, NC
Website
www.kindredspiritscsg.com
Is anyone running additives in their mechanical injected diesel?
I read somewhere that the ultra low sulfur diesel has less lubricative properties than the older diesels and has an effect on the injection pumps.
I have heard of people adding 2-stroke oil to their fuel.
Is this something to be concerned about or is it just internet BS?
If your only concern is lubrication, then veggie oil or 2-stroke oil (non synthetic and non marine grade) is fine.
Lubrication additive is only a concern with rotary injection pumps. Inline injection pumps are lubricated from the crankcase.
While it is true that our pumps are lubed from the crankcase, the upper part where the fuel goes through it is not. Sulphur used to take care of lubricating the moving parts that don't get oil just fuel. Same goes for the injector tips, tips don't move much but they do move and all they get is fuel.
Stanadyne helps replace what was lost with the low sulphur fuels. It supposedly helps keep the system cleaner as well, less smoke etc. I have to admit it cleared up some minor problems with my 3B, (with the inline pump)
Tony
I have never purchased stanadyne, is there a way to order it over the internet or do you have to go to a dealer?
Also how does it compare to adding 2-stroke oil to the fuel?
I use amsoil Diesel Fuel Additive Concentrate beacuse A. I have heard good things about it B. I have been using Amsoil products in everything i have owned for over 13 years now and it has never caused me any problems C. its cheaper than Standyne
OR
When I can get a hold of it... I will put in 5 Gal of B20 Biodiesel with every tank.
If i could i would run a Jerry can of B100 bio in every tank if i could find it or make it myself.
Phil
Might look for a website to see who sells it, I work in a diesel boat yard and we stock it.
At least one of the old school diesel mechanics says that 2 stroke oil will do the same thing but I don't know the ratio for dumping it in the fuel. Others swear by Stanadyne.
Tony
2 stroke is popular, but there have been several studies published which say its not very good. In particular I can recall one such that found using plain veggie oil as an additive was several times more effective. I can't find that link, but the best I could find this time around was this one:
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
http://www.natbiogroup.com/docs/education/lubricity additive study results.pdf
I've been using a kleen-flo diesel conditioner product with every tank in mine.
I see they only looked at the marine grade 2-stroke oil. It makes me think they had some sort of bias going on. It doesn't take much searching on the subject to find warnings not to use the marine grade 2-stroke oil. I am not sure why.
I am have been using Power Service Diesel Supplement + Cetane. I find that it does a very good job at cleaning injectors. I was ready to pull mine but tried this after a friend told me about it. All I did was add it to two tanks in double dose and the smoke was gone. Now I just add it for the lube and the extra cetane. Here's a Canadian Tire $3.00 off coupon valid till the end of Sept.: http://www.canadiantire.ca/affiliates/promo/autocoupon/pdf/0380730_en.pdf
I run optilube XPD and notice that it's a little quieter, starts easier, smoother and has a little more power. I really like it so far. I also try to run some bio during the summer months.
I am currently running the same stuff and I am quite happy with it.
I originally ran howes in my HDJ81 and I decided after the first bottle of it in my 77 that I would try the power service because I heard good things about it. Slightly better fuel economy on it, yeah I am sold.
I am quite generous with the fuel additive when I fuel up.
300mL everytime I fill up. Might try a double dose here after I clean my air filter and put on a pre-cleaner for my snorkel.
I have heard 2 stroke oil can gum stuff up but I don't know for sure. The prince george injection shop apparently swears by the stuff.
Yup, Biodiesel :hillbilly:
Hi there,
I've been running SVO for four years plus and it seems to enjoy burning grease than diesel. I do use fuel conditioner when I come upon some on sale. Lately, it's a product by Gummout. 1.99/L at Mardens surplus.
Any diesel rig can run up to 50% clean veggie oil in the summer. Any more than that and it starts hard with white smoke. There's no difference if you run 20% SVO and it acts like an awesome fuel lube for your pump and injectors. The bonus is saving 20% on fuel costs. I run 100% svo after warming her up on diesel to operating temp. It loves it.
SVO also seems to keep EGTs lower as well. I estimate about 75C difference. For instance this weekend I hauled my trailer loaded for 1300kms on grease running around 14psi of boost and never exceeded 525C pre-turbo EGT on hills as compared to almost 600C on 80/20 diesel/svo blend.
Went to that link in Amaurer's post and I am not sure how the test translates into real world info. They used diesel that had no additives (which is not likely to happen out of the pumps) so what would happen to those additives used with commonly available diesel? The link is a good read to learn from but would like to hear from anyone using just 100% bio diesel as an additive in fuel from the pump. That test compares the additives themselves but what about how they would react in fuel available from the pump.
Seems odd that a lot of guys are getting better results than that test would lead us to believe. So in reality I still don't know what I should run in my diesel!
And a question for you veg oil guys, Do you need to change out fuel lines when you run a lot of veg oil?
Tony
